Svigor opened this issue on Dec 05, 2004 ยท 11 posts
Svigor posted Sun, 05 December 2004 at 6:51 PM
Teresa is wonking out on me. I load V3 and apply the Teresa morph, it works, but her eyeballs seem to stay where they were (which means they pop out of her head!). The only thing I can think of is that I'm using V3 Sr2, and maybe Teresa wants V3 Sr1. Has anyone else had this problem? Can I install V3 Sr1 over Sr2, or do I need to do something more complicated?
randym77 posted Sun, 05 December 2004 at 8:29 PM
I don't think it's the version. I just tried it with SR2, and it works fine for me.
What version of Poser are you using?
Svigor posted Sun, 05 December 2004 at 9:22 PM
P5. I can't think what it could be. Maybe it's because I fiddled with Vic's pbm morphs (yanked them out with morph manager because they piss me off)?
Message edited on: 12/05/2004 21:23
randym77 posted Sun, 05 December 2004 at 9:30 PM
That's probably it. I don't think custom morphs will work correctly with them. Try reinstalling V3. You can save the PBM-less version under a different name first, if you want.
Svigor posted Sun, 05 December 2004 at 11:44 PM
I didn't add any custom morphs, I just deleted the empty slots that start with (pbmdc and pbmcc or whatever they are). I'll give it a go with a standard V3 though just in case, thanks.
xenic101 posted Mon, 06 December 2004 at 12:07 AM
She does that to me sometimes too. I applied another morph after the Terese morph to get a different face.
What I found to fix it is;
Svigor posted Mon, 06 December 2004 at 12:33 AM
Thanks xenic, that sounds like it might do the trick. I though it might be something like that but I'm always scared to mess with that axis stuff.
Svigor posted Mon, 06 December 2004 at 12:59 AM
Yep, that did the trick, thanks again!
Puntomaus posted Mon, 06 December 2004 at 1:25 AM
The problem might be that you have deleted the empty channels since they are used to inject custom morphs. The inj morph for Teresa's custom headmorph uses the PBMCC_01.
Message edited on: 12/06/2004 01:28
Every
organisation rests upon a mountain of secrets ~ Julian
Assange
randym77 posted Mon, 06 December 2004 at 9:10 AM
What Puntomaus said. You may not have thought you added any custom morphs, but the Teresa morph is a custom morph. Without those PBM channels, any character that uses custom morphs probably won't work correctly.
Svigor posted Tue, 07 December 2004 at 11:22 PM
Ah, okay - still, xenic's suggestion fixed the eye problem.
