kuroyume0161 opened this issue on Dec 06, 2004 ยท 2 posts
kuroyume0161 posted Mon, 06 December 2004 at 1:50 PM
I have Poser 4.03, Pro Pack, and 5 SR2 installed. The VM setting is 2GB. 4.03 and 5 work well, but Pro Pack has the dreaded unusable Document Window (gray square with rest white, nothing showing properly). I have the Memory Updater, but every time I attempt to run it on my Pro Pack install, it says that it isn't a valid install. It runs on 4.03 and 5 (which is unnecessary). I own all versions. Yes, resetting the preferences doesn't fix the problem. I thought that I had applied the Memory Updater during install, but I have since added more memory to my computer (now 4GB, but only 3 is seen by the WinXP) and changed my screen resolution from 1600x1200 to 2048x1536. But setting it back to 1600x1200 doesn't resolve it either (unless I have to reset the preferences afterwards). Any thoughts on a solution to the problem?
off.
-- Bjarne
Stroustrup
kuroyume0161 posted Mon, 06 December 2004 at 2:06 PM
Got it. The memory updater in my Poser Pro Pack install folder is for Poser 4.03 (which explains why it updated it without problems). That discrepancy is fixed. I used it since CL's website was unavailable for a while there and couldn't verify the updater. Once I got in and could download the proper one, it worked. Geez... ;)
off.
-- Bjarne
Stroustrup
