Subject: Damian
Marque opened this issue on Dec 17, 2000 ยท 15 posts
Marque posted Sun, 17 December 2000 at 10:36 AM
Has anyone here bought the Damian map for Michael? I'm having a problem with the body texture part of it. It's wrinkled and really looks bad. Anyone know of a workaround? I got him a while ago and just checked it out today. I have checked and rechecked to see if I have something loaded wrong. Any ideas? Marque
JeffH posted Sun, 17 December 2000 at 11:35 AM
E-mail the author about it is all I can suggest.
Marque posted Sun, 17 December 2000 at 11:43 AM
Just wondered if anyone else had had this happen. Thanks Jeff I will. Marque
movida posted Sun, 17 December 2000 at 2:06 PM
I bought it and it works fine here - I think he's just hairy g what resolution are you running your monitor at? Try 1280x1024 if you can and 24bit color
nitreug posted Sun, 17 December 2000 at 2:15 PM
I got Damian too but did play too much with him yet. When I look at your image, I do not see what is wrong. What wrinkled mean? Sorry I am french. Claude
Lorraine posted Sun, 17 December 2000 at 5:07 PM
I got it and I like it. I did have to turn down the bump map on the body; also turn down the texture a little and you will see some variations...
Marque posted Sun, 17 December 2000 at 5:24 PM
That might be it, thanks Lorraine. Marque
nitreug posted Sun, 17 December 2000 at 5:24 PM
How do you turn down a texture and bump map?
kevinchn posted Sun, 17 December 2000 at 7:04 PM
I bought the Damian map and I think mine looks weirder.The bump map on the lips don't seem to match the texture map.
Marque posted Mon, 18 December 2000 at 10:24 AM
Thanks, I thought it was just me. I think it's time to start making my own now that I'm finding fault in others. 8^) I turned down the bump map on the body and the head and it still looks bad to me, just won't use that one. Marque
Catharina Przezak posted Mon, 18 December 2000 at 3:21 PM
Attached Link: http://www.renderocity.com
What I see on this image is wrong using of bump maps, you must use also the anti-alias for the rendering the maps are made for users that made a images with big format min 800x600 if you create a small image it will not working corect. If you still have problems with the body don't not use the bump map with 100% only with 50%, you are the first person that have problems with the maps. Wish you much succes with your rendering and if you have any problems just e-mail me to cathrin@worldonline.nl .
Catharina Przezak posted Mon, 18 December 2000 at 3:32 PM
I don't see any problems with it?
Marque posted Mon, 18 December 2000 at 6:04 PM
Thanks for getting back to me, I'll try that. But one other person did complain if you look above kevinchn is also having a problem. Marque
Lorraine posted Tue, 19 December 2000 at 1:41 AM
The bump maps and the texture maps can be adjusted using the little slider bar under the little menu where you choose the name of the file. I think it just takes a little practice and the maps come out very nice. I liked this map particularly ...also fool around with the lighting and the other settings on the render material options
Marque posted Tue, 19 December 2000 at 8:57 AM
Thanks for the help, that's why I came here first so I could maybe find some workarounds before emailing the creator. I was not complaining about the product, only trying to find out how to get it to look better. 8^) Marque
