Subject: What is different pp with p4?
smalll opened this issue on Dec 06, 2004 ยท 3 posts
smalll posted Mon, 06 December 2004 at 10:29 PM
Hi! I downloaded pose file. There was two pose file. One is for pp and the other is for pp. Could you teach me What is different pp with p4,please?
randym77 posted Mon, 06 December 2004 at 11:50 PM
The bump maps are different. ProPack uses *.jpg files for bump maps. Poser 4 uses *.bum files. If you have Poser 5, you should use the PP version. You will probably have to adjust the bump maps, though, manually attaching them to Bump node.
konan posted Tue, 07 December 2004 at 7:23 PM
Also, I believe Pro Pack uses PNG files for the thumbnails instead of RSR files.
Konan (Creator of Blacksmith3D)
Blacksmith3D - Morph - Paint - Suite
Reshape Objects Easily. Paint textures in true 3D.
Import/Export Poser CR2 or OBJ files.
New version available (December 3, 2004)
http://www.blacksmith3d.com
