larry opened this issue on Dec 09, 2004 ยท 11 posts
larry posted Thu, 09 December 2004 at 11:12 AM
Hi there. I am transporting V3 and Paradise hair into Vue 5 as a PZ3. V3 shows up but the hair doesnt. Whats wrong here? It is someting in the settings thats set wrong? Havent seen a post about this anywhere else. Thanks
Phoul posted Thu, 09 December 2004 at 11:15 AM
What is Paradise hair? Could you share captures?
larry posted Thu, 09 December 2004 at 11:19 AM
Paradise hair is made by 3Dream. Its in the Marketplace.
Phoul posted Thu, 09 December 2004 at 11:22 AM
Have you render (or capture) to show us your problem?
nanotyrannus posted Thu, 09 December 2004 at 11:41 AM
Well, I checked out the product and it doesn't say whether it's poser 4 or poser 5 but based on the fact it has morphs I'm guessing this might be Dynamic Poser 5 Hair? If that is the case Vue 5 can only import it by using the Mover 5 add-on. That's just my guess though.
XENOPHONZ posted Thu, 09 December 2004 at 11:45 AM
You might want to check to see if the hair's .obj geometry file is in a location other than the default P5 Geometries folder on your C: drive.
I don't have either Vue 5 or the Paradise Hair -- but .obj file placement in any location other than the default P5 Geometries directory can cause the same import problem in Vue 4 Pro.
gillbrooks posted Thu, 09 December 2004 at 12:07 PM
Gill
larry posted Thu, 09 December 2004 at 12:20 PM
No. I did not parent the hair to V3. I will have to give that a try. Thank you..
luvstruckme posted Thu, 09 December 2004 at 2:51 PM
Hi, I am new to Vue. I had a similar problem last night, V3 imported well but SLINKY HAIR did not. I checked and the texture transparancy was set to 100% on all surfaces. I reduced these and the hair was showed up. I hope this helps.
nanotyrannus posted Thu, 09 December 2004 at 3:10 PM
Interesting, thanks for the tip, I hadn't tried it yet but I do have that hair pack and that saves me a question on the forum, Thanks!
svdl posted Sat, 11 December 2004 at 4:19 PM
Sounds like the transmap got lost. Paradise Hair is P4 transmapped hair, transparency SHOULD be at 100%! I use Vue 4.5 Pro, and all transmapped hair works perfectly.
