Forum: Fractals
Subject: Fractal Explorer problem
kymarto opened this issue on Dec 13, 2004 ยท 7 posts
kymarto posted Mon, 13 December 2004 at 6:22 PM
Hi FE people, I recently downloaded the latest version of Fe--2.01, and whenever I try to work with the Sterling formulae I am rudely informed that the Sterling library is missing...v 2.0 the same, no dice. I wrote to Arthur but got no reply. Anybody have the full thing or know where I can get it? TIA, Toby
kansas posted Tue, 14 December 2004 at 10:46 AM
I use version 2.00 beta 1 and don't have any trouble with the Sterling library. I didn't care for the newest version. Marion
Pannyhb posted Tue, 14 December 2004 at 10:49 AM
Hi Toby, If you have any older version of FE, copy and paste the file ftloo01.dll into your newer version. That should do it. I can send it to you if you want:) Panny
kymarto posted Fri, 17 December 2004 at 6:09 PM
Thanks Panny, that works. I wonder why Arthur released the new one without that dll... Hi Marion. I downloaded the release 2.00 and it also is lacking the Sterling library for some reason. My older versions have it luckily. Toby
kansas posted Mon, 20 December 2004 at 12:13 PM
Hi Toby, I'm sorry to hear that the Sterling library still doesn't work. I haven't used FE for a while, but the other day I opened it and the compiler is messed up. I DL it again and am still having error messages. Very puzzling. Marion
Cosine posted Mon, 20 December 2004 at 9:02 PM
Take a look here. All the "extra" files should be here. If you can't get it working IM me. http://www.fractalfairy.com/~feusers/fefiles/index.html Dennis
Pannyhb posted Mon, 20 December 2004 at 9:14 PM
And I uploaded new versions of FE 2.00 and FE 2.01 that include the missing .dll for sterling to my website, too. Marion, I don't know why your compiler isn't working correctly, you might need to download it again (if you don't have a copy on hand) and overwrite the files in your FE folder. If a DOS window appears and FE seems to do nothing, just hit the "close" button on the DOS window and see if the fractal computes. Hope this helps.
