Subject: Scaling conforming clothes?
mbaucco opened this issue on Dec 20, 2000 ยท 3 posts
mbaucco posted Wed, 20 December 2000 at 8:45 AM
Hello, If you change the scale of a figure, is it possible to have conforming clothes that fit? I have tried scaling the clothes after conforming them, but received very odd results. Should I scale them to match the figure first, and then conform them, or should I conform them then scale them? Is this even possible, or are you stuck with having to use an unscaled poser figure with conforming clothes. Thanks in advance for any help! -Matt
JeffH posted Wed, 20 December 2000 at 8:56 AM
Attached Link: http://www.renderosity.com/messages.ez?ForumID=10139
There's a thread in the Poser Technical Forum with just this subject: http://www.renderosity.com/messages.ez?ForumID=10139 Maybe there's a solution for you there. -JH.
shadownet posted Wed, 20 December 2000 at 5:28 PM
What I normally do is conform the clothes to the figure, resize the clothes, then go to edit/memorize figure (making sure that the clothes are selected. Now you can save the clothes to the library. When you load them again, and conform them to the figure they will conform properly for that size. Hope that helps. An example is Nerd's Clara Claus outfit resized to fit Saluda (vicky). Rob
