duanemoody opened this issue on Dec 20, 2004 ยท 5 posts
duanemoody posted Mon, 20 December 2004 at 2:44 AM
Indoda posted Mon, 20 December 2004 at 5:41 AM
Thanks for your post I was about to try that on a garment that doesn't quite conform but wasn't sure if it would work. Now I'll definitely give it a try.
The important thing is not to stop questioning.
- Albert Einstein
Indoda
duanemoody posted Mon, 20 December 2004 at 8:07 AM
This also means I can use clothing built for other figures (within reasonable limits). But you all knew that already, right?
greetinx posted Mon, 20 December 2004 at 8:47 AM
Trying the cloth room in Poser 5 is always worth a try... the most important thing is that the mesh is only one-sided. Most of the rest you can tweak somehow.
duanemoody posted Mon, 20 December 2004 at 10:50 AM
Yeah, I figured if the sleeves looked transparent inside in the Pose room that they were one-sided, but since the figure mapping comes through intact when imported as a prop it was probably a non-issue (i.e. I can apply all the same textures the same way).
