Forum: Photoshop
Subject: Color Management
pa902 opened this issue on Dec 23, 2004 ยท 12 posts
pa902 posted Thu, 23 December 2004 at 5:35 PM
I'm totally confused about color management in Photoshop7. I look online but nothing I read is in simple english. When I open a document it give me options to keep settings or discard color management. The color management dialogue box has so much stuff I don't understand. I just keep it at the default but I would like to know what Im doing in there. Can anyone tell me or show me a good site where this stuff is explained in english. And if my epson prints in CYMK why do I leave my photos in RGB for printing? Thanks very much
killer3d posted Thu, 23 December 2004 at 6:08 PM
CMYK is a vector graphic format and RGB is a pixel based format. The two are completely different. Color Management is most used when out put to a Service Center and for the most part from what I have learned from them is that you really only need to use a default color profile for RGB when creating or viewing your work on the computer... when you take something to them or have them do the printing for them if needed "they" will apply a correct color profile for you. However there isn't anything wrong with applying one yourself but there are many for many reasons, If you have Adobe Illustrator version 7 on up and have all of the hard copy documentation that comes with the box it has an excellent small book on color management and the differences and uses of it. Adobe Photoshop abd Corel Suite also have extensive electronic and hard copy documentation of the subject but in my own opinion a common rgb profile applied to your artworks (sRGB IEC61966-2.1) and or an ICC Profile when exporting JPG's for the web allow others a generic profile that affords ready printable images from your desktop. When you get off into the CMYK world in that sense the same basic generic rules apply however depending upon what type of job you are sending to have printed or whatever machine it is being printed on will dictate the type of color mangement profile to embed into the work. When utilizing a software like say InDesign 2 or Quark you may well have mixes of both RGB and CMYK art throughout it (the publication that is...) and then you will need to read up more regarding "Bleed" and "Spot Colors" and when you do those attributes will explain in depth the reasons for color management and when it is best to utilize a particular profile or not at all. Your local Public Library and even better yet a local print shop will have all kinds of Art Print documentation the local print shop will "I am certain" be more than delighted to answer questions you might have regarding this topic and you should walk away totally enightened by the better understanding and knowledge you have attained as well as the smarts you exersized using the initiative to ask. :) I hope that, that at least helped to answer your question. That is a very good question and something that every artist should know about. Good luck!
Hoofdcommissaris posted Fri, 24 December 2004 at 4:40 AM
Attached Link: Very useful link!
I am sorry, but I must say that some of what killer3d says is nonsense. His or her words read like an alternative reality. The first sentence is so far from reality that I can't even grasp how he or she ever composed it. **CMYK** are the four color full-color print is made of: cyan, magenta, yellow and black (the 'K' comes from 'key'), when a document is printed (also on inkjetprinters) all colors you see in print are made out of these inks, mixed by printing them in small dots (screen). The more ink, the darker the color. **RGB** is the way colors are created by light on monitors and tv screens. Red, green and blue are the basic light colors, with which ANY known color can be created. The more light, the lighter the color. *(there is no connection whatsoever between cmyk and vectors and rgb and pixels... the only link could be that in Illustrator and Corel the standard modus is cmyk, but you can work in rgb if you want, as you can change your document in Photoshop to cmyk)* **Color Management** does NOT start when you are outputting to a service center, unless you REALLY like gambling, have all the time of your life and plenty of cash to spend on reprints and retrying and searching for other printers because the one you choose 'did a crappy job'. One of the reasons color management is needed is the big difference between watching colors on a piece of paper and watching colors on a pc screen. Because one is ink and another one is light. One of the biggest disappointments if you are learning yourself creating stuff on your computer and fiddling around in Photoshop, is printing your material, especially if it gets printed in off-set or similar professional processes and discover that a lot of your preciously chosen colors are somehow changed in to something that looks like an old painting that has been lying in the mud. The reason: in CMYK you can print a smaller range of colors than you can see on a tv or pc monitor. Especially the really bright colors on-screen (remember the red, green and blue) are dull when printed. So why does color managment come in to place earlier? It can help you working on what you can actually achieve when outputting stuff to paper, because it can make you see what the end result will be, instead of what a monitor can do. Actually, it is kind of logical. If printing is your end result, you should work toward that. The same would be true if you are designing a murial, you should only the paint you have bought... When making artwork (or designs and lay-out) there are several pieces of hardware in the workflow that collect or output color information, your scanner, your camera, your monitor, your inkjetprinter. The ideal situation is, that every part of the pipeline is build for the final result: print. There is not only a problem with the cmyk and rgb difference (it will be referred to as 'gamut' in documentation), another reality is, that a lot of hardware has standard handicaps that should be corrected in the process. For instance, lots of digital camera are simply taking too blue photographs. And lots of scanners' result is too red, especially when the lamps get older. That is why in your systems profiles are everywhere and you have all those choices in the dialog box. If you want to output on a professional level you will have to deal with these matters. Most print shops or printers will NOT accept documents that have mixes of RGB and CMYK in them. One of the reasons is that they do not want to be accused of doing a crappy job. They want you to know what the end result will be, color-wise, so you will pay them for what they deliver. I am a professional designer and have to deal with this stuff on a daily basis. I will try to do a short run-through of our handling of it: - Scans are made in CMYK. Well, not really ofcourse, a scanner works with light, not ink, but the software that comes with professional software does the conversion, compensating all characteristics of the scanner AND making the best cmyk version possible. This requires to make profiles for the scanner once every 3 months, because of the degenaration of the lights in the scanner. - If scans are delivered from external sources we will change the modus from rgb to cmyk (using the standard conversion of adobe) and corrected if needed. If there are drastic changes that will bother the client of people who sent the scans, we will make a jpg to show them how the result will look like (a jpg is in rgb again, but now only with colors that can be printed). - Digital photographs are converted from rgb to cmyk and corrected. If there is a profile embedded it will be taken into account. - Manipulations of color, collages, photo montages and whatever you want to use Photoshop for are mostly done in rgb, but mostly with material that has been changed to cmyk and back, to get rid of the colors that can not be printed (and are useless, actually). The documents are less 'heavy' (cmyk uses for channels of information, rgb three) and a lot of filters and layer effects are designed to work in rgb. - Lay-outs are made in InDesign (sometimes in Illustrator). In the design phase the mix between rgb and cmyk, mostly because it is just to much work to make a flat cmyk version after every change. But when looking at the screen, a lot of the time you want to see what you are making, not what is possible to make with light on a computer monitor. So before sending desings to a client (via pdf file most of the time) we will make everything cmyk. As a rule of thumb lay-outs are in cmyk. As for profiles: we do NOT embed profiles in our documents, because there is actually a unique profile for EVERY print machine (but people tend to generalize per model ;-) and a lot of time we do not know which machine will be used. So when saving photoshop files, NO profile is better than the wrong profile. More and more jobs are deliverd as high resolution pdf files (for advertisements we use Certified pdf files, that do require output profiles, that are standardized for all magazines and papers), which only will have the correct end result if they are built right. You do need to know this kind of stuff if things tend to get 'professional', otherwise you will 'sell' your stuff with a look that can not be achieved in print. That spells p.r.o.b.l.e.m. and can result in reprints that only have one payer, you. I found the link above very helpful. Sorry if I seem harsh, but I had to react to informatin that is wrong. I understand killer3d wants to help, but it seems his knowledge is a bit too hear-say. It will probably work for his way of working and understanding of the (print) world, a lot of other people could be brought to wrong conclusions.
pa902 posted Fri, 24 December 2004 at 9:31 AM
Thank you for clearing that up and for the link
RHaseltine posted Fri, 24 December 2004 at 9:43 AM
Although desktop inkjets use CMYK inks, they are RGB devices unless you have a Postscript RIP for them (in all but the highest end cases that's an additional purchase, often over $100 - sometimes way over). If you aren't aiming for commercial output you would probably be best sticking with RGB throughout (I do, with an Epson 1270 as my printer). In order to use CM you must have accurate profiles for your display and peripherals - those tell CM-aware software what actual colours your monitor or printer produces given a particular set of RGB (or CMYK for high-end printers) values, and what the RGB values your input devices report represent: canned profiles for your scanner and for the manufacturer's ink and paper may be better than nothing (I hope) and there are free software calibrators such as Adobe Gamma (included with Photoshop) which will at least get somewhere close. With most current software you pick a working space, which like the profiles specifies a relationship between numbers and real colours, and the software sends the appropriate RGB/CMYK values to the output device to get a colour as close as possible to the desired value. Incidentally, Hoofdcommissaris, the point of embedding a profile is not to describe the output device, but rather to say what the designer wanted the colours to be - the printer should then work to match those colours as closely as possible. If you don't embed I assume you send some kind of hardcopy instead, otherwise the printer has to guess your intentions.
dreamer101 posted Fri, 24 December 2004 at 11:44 AM
Thanks for being harsh Hoofdcommissaris. I too could not believe what I read on post #2. I was going to post a correction but my jaw kept on hitting the keyboard. Users who have absolutely no idea what they are talking about should not answer questions. Stick with what you do know.
retrocity posted Sat, 25 December 2004 at 1:08 PM
yes thanks guys! good info hoof!!
bonestructure posted Thu, 30 December 2004 at 5:13 AM
Here's the problem. RGB handles pretty much any color. CMYK, on the other hand, while it will handle any color on your computer, when it's sent to a printer that uses the CMYK print process, those colors may change as CMYK printing uses a very specific color profile. So, if you're making a graphic which is intended to be printed, you use CMYK so that the colors you create in the graphic will print accurately as you created them.
karosnikov posted Fri, 07 January 2005 at 1:49 PM
basicly so you don't give incorrect ink % to a different printer- an image that doesn't suit X, will print different on Y and Z. RGB, if it's colour corrected holds a nutral grey ballance in the highlight , midtone, and shadow areas of the image, this can simply be 'converted to cmyk to suit a profile of just about any printer, and concrete wont look green.
Hoofdcommissaris posted Mon, 10 January 2005 at 4:35 AM
In the future, besides from the flying cars and robots that will clean your house, you can expect to work in RGB most of the time. A profile will be attached to your file, and whatever apparatus will output your file (a monitor does provide output as well) accordingly to the possibilities and limitations of it. Files will be flexible and converted 'on-the-fly' when needed. 'Under the hood' photoshops works in LAB, if I remember correctly, but I keep as a rule of thumb that I keep the hood closed. Only when things go really bad (smoke and all) I will open up things like that, and look like a pro doing so. Hands on hips and all. After that I expect things to go back to normal, because I know zilch about cars. But that is another subject alltogether.
ChuckEvans posted Wed, 12 January 2005 at 7:54 AM
Nice information. Thanks!
Hoofdcommissaris posted Wed, 12 January 2005 at 8:14 AM
Warning though: the flying cars are still way under development.
