kruse opened this issue on Dec 25, 2004 ยท 6 posts
kruse posted Sat, 25 December 2004 at 3:58 PM
Hi all,
we tried to add another face morph. We had choosen P5-Judy for this try.
What we did:
We tried this morph. It's working fine, but the whole head is becoming distorted by using this morph. Funny thing, because the eyes are not moving and the nose is squeezed.
Any ideas, what we made wrong? Any ideas how to manage it?
Thank's in advance
Have a nice day
Daniel + Matthias
nickedshield posted Sat, 25 December 2004 at 4:07 PM
Before exporting did you make sure Judy was zeroed? Windows>Joint parameters, zero figure. I can't remember if you have to include or exclude the eyes when you export.
byAnton posted Sat, 25 December 2004 at 5:47 PM
Was there other morphs active on the head you exported? I am not sure what you mean but if you exported the head with dials active, then those morphs are distorting the head and squeezing the nose? Merry Xmas, Anton
-Anton, creator of Apollo Maximus
"Conviction without truth is denial; Denial in the
face of truth is concealment."
xantor posted Sat, 25 December 2004 at 10:14 PM
Could you show a picture of judy with the morph applied?
vilters posted Sun, 26 December 2004 at 3:28 AM
First remove the IK for the R and L legs> Then zero the figure in the joint parameters. Check that the hip is at x 0000 and y 0000. then check that the body is at x 0000 and y 0000. Then save the group you want to morph as a morph obj> Then I take the free anim8or and play with it. Works every time
Poser 1, 2, 3, 4, 5, 7,
Dev
"Do not drive
kruse posted Sun, 26 December 2004 at 6:32 AM
Hi all,
thank's a million, problem is solved now.
We found out the reason for this problem with your help. First we forgot to mention this Judie was modified in faceroom. So we checked the nose and found values above zero. After we set all dials to zero, the nose wasn't distorted anymore. Also after we set Judies joints to zero, the head wasn't moving forward by using the dials.
Have a nice day and thank's again
Daniel + Matthias
