Forum: Bryce
Subject: Bryce Failure upon .dxf import
rdhceo opened this issue on Dec 25, 2004 ยท 11 posts
rdhceo posted Sat, 25 December 2004 at 5:12 PM
Any of you use Elefont? I was using this software to create .dxf files and importing them for some time. For some odd reason - now when I import files from Elefont in this format - Bryce collapses. There is an error message which is quite long - and mentions .dll files. I would include the message here - however, the error message seems to disappear from my system - the file folder where it is supposedly stored is always empty when I attempt to locate the message. I have deleted and re-loaded Elefont without success, also - I do NOT wish to delete and re-load Bryce (all of my models, textures, etc.) Any helpful hints or direction toward tutorial assistance would be appreciated. Robert
danamo posted Sat, 25 December 2004 at 6:43 PM
I had the same prob with Elefont, and it happened all of a sudden like your situation. I finally started using Wings3D for making text(works great) and you can export the text in Wings in .obj, or 3ds files as well as several others.
Nukeboy posted Sat, 25 December 2004 at 7:34 PM
Try reloading Elefont. Sounds like it is creating corrupted files. Or, try importing a dxf file from another source. If that crashes Bryce, then you know it's Bryce. If it works, then you know it's Elefont.
rdhceo posted Sat, 25 December 2004 at 10:41 PM
Thanks for the ideas. I heard of a program called crossroads - that converts .dxf into .obj files. I cannot locate the link or site to utilize it though. I did try to reload Elefont - without success. Funny thing - I import some pretty heavy Poser and other models into Bryce - and the program seems to hold it's own during this process. For your consideration - I thank you.
erosiaart posted Sun, 26 December 2004 at 2:46 AM
kept happening to me..I landed up unintalling and reinstalling bryce..it worked..have no idea why...
Erlik posted Sun, 26 December 2004 at 5:20 AM
Well, you can always try another approach. Find Tiffer or Tiff2PGM somewhere here in the free stuff. With that, you can create a tiff file in a 2D image editor, converting it to pgm and importing into Bryce. You'll get much smoother mesh that way.
-- erlik
dan whiteside posted Sun, 26 December 2004 at 7:33 AM
Crossroads appears to be gone - the link I've always used is: http://home.europa.com/~keithr/Crossroads/index.html but that's now "Forbidden". Really too bad, it was a useful app.
pakled posted Sun, 26 December 2004 at 11:40 AM
Attached Link: http://www.wings3d.com
hmm..guess he had to change the baby pictures..you can do 3d models of text in any font in Wings 3d..and in .obj format as well..here's the link..in case you haven't heard of us..;) wings local 509..;)
electroglyph posted Sun, 26 December 2004 at 11:49 AM
Attached Link: http://www.3dcafe.com/asp/meshes.asp
3dcafe always has a selection of dxf files at the end of it's freestuff models. Pick a category and you can download hundreds to try out. If they work in Bryce then it's elefont.
jelisa posted Tue, 28 December 2004 at 12:37 AM
Attached Link: Crossroads download here
I found a copy of Crossroads on some backup disks and installed it. I read the license agreement and it allows the program to be redistributed as long as it's not charged for. So ... I've placed it my site, available for download. It will be there as long as my host doesn't scream about bandwidth.
dan whiteside posted Tue, 28 December 2004 at 7:10 AM
Thanks jelisa!
