gpacioli opened this issue on Dec 25, 2004 ยท 19 posts
gpacioli posted Sat, 25 December 2004 at 5:33 PM
Possible and how best to export a Poser animation to Flash
gpacioli posted Sat, 25 December 2004 at 5:34 PM
Joe Strata says it can't be done.
Jaqui posted Sat, 25 December 2004 at 5:45 PM
export to a series of stills. import each still as a single frame into flash. or, select all and cast to time. but not directly from poser.
Argon18 posted Sat, 25 December 2004 at 6:06 PM
I've seen it had an option to save as .swf in the animation file formats but when I tried it in Poser 5 it didn't work out so well since I couldn't read the swf. I have done the render to .jpg each frame and import them 1 by 1 and it works pretty good.
Click to get a printed and bound copy plus T-shirts, mugs and
hats
lmckenzie posted Sat, 25 December 2004 at 8:43 PM
Attached Link: http://www.quiss.org/swftools/
Haven't tried it but you might look at SWFTools which is supposed to have jpg2swf and avi2swf capabilities. Not a direct option but possibly useful."Democracy is a pathetic belief in the collective wisdom of individual ignorance." - H. L. Mencken
jwhitham posted Sat, 25 December 2004 at 10:38 PM
Attached Link: http://www.renderosity.com/messages.ez?Form.ShowMessage=1976031
Reading the thread at the above link may help.dhenton1000 posted Mon, 27 December 2004 at 2:45 PM
Attached Link: Flash poser
heres one shot at it. black and white only at this time. Look for the index like called inkcmdgpacioli posted Mon, 27 December 2004 at 5:34 PM
yeah! that is it.
InfoCentral posted Tue, 28 December 2004 at 1:28 PM
Inkulator? I was reading the pdf file and it didn't mention anything about animating with it but it sure shows a B&W animation with Poser 5 on the opening screen. Have you tried this program out?
InfoCentral posted Tue, 28 December 2004 at 1:45 PM
I guess I should say Ink9000 not Inkulator. I did notice that there is a command line renderer. I guess this is where the animations are done. But what about Poser's own Sketch Designer. Isn't it possible to produce the same thing with it?
dhenton1000 posted Tue, 28 December 2004 at 2:39 PM
infocentral-- The inkcmd feature is not in the manual. The reference page is all there is. The idea is to use poser to produce a series of obj files, then create a batch file that calls the inkcmd exe for each obj file, and turn it into an *.ai file. Flash then will recognize these as a sequence and pull them in. That's how I did the animations that you see on the page.
gpacioli posted Fri, 07 January 2005 at 6:02 AM
When I export Poser to Flash (because to publish on the web) I get a crappy cartoon like figure. Surely Poser-to-Flash works better than that --- or else what's the use of exporting to Flash anyway --- I am stuck using all Macintosh software and hardware --- can't afford to start over with .obj system. What do you think I should do other than 'dump this thread and search' ?
SteveJax posted Sun, 09 January 2005 at 7:23 AM
Attached Link: http://www.swishzone.com
Save to AVI and convert to SWF using SwishVideo. You'll find an example of one I did on my www.lostin3d.com Opening Page.gpacioli posted Sun, 09 January 2005 at 6:32 PM
Thanks, you are very helpful and I tried what you said and it worked ! I am now trying to convert .obj files to files I can open in any of the programs that broke me to buy viz. photoshop, illustrator, strata cx, fireworks, text edit, note pad, gif maker, flash, --- what's the deal with .obj files --- how can I learn more about converting files back and forth? I really like Poser and want to become agile with it and nimble. Thanks again for your helpfulness.
SteveJax posted Mon, 10 January 2005 at 1:03 AM
Attached Link: http://www.micromouse.ca/
You can convert OBJ's and many other 3D file formats using Accutrans from this link:gpacioli posted Mon, 10 January 2005 at 7:30 AM
Thanks Steve, There I go, stuck again. Accutrans is PC only and I was dumb for Apple.
SteveJax posted Mon, 10 January 2005 at 8:00 AM
Hrmmm...Well since you've gone and stumped me there all I can suggest is a google search on "3D File Conversion".
gpacioli posted Mon, 10 January 2005 at 11:15 AM
Hey, Great Suggestion! I know to do it but didn't think of it in the heat of battle. Thanks.
lmckenzie posted Tue, 11 January 2005 at 2:27 AM
Look under the topic forums over on the right. There is a Macintosh forum. They can probably help you with more information on 3D applications for the Mac.
