Subject: Help w/ Animation Master and Poser
sama1 opened this issue on Dec 23, 2000 ยท 4 posts
sama1 posted Sat, 23 December 2000 at 1:09 PM
I read somewhere it is possible to use Animation Master to create Morph Targets, but after spending 5 hours I still keep getting exploding objects in Poser. Can anyone tell me what the procedure is to get the morph target back into Poser? Thanks in Advance, Sam
Mason posted Sat, 23 December 2000 at 4:26 PM
Sounds like the MT is out of scale. I had the same problem in 3d studio. MTs are extremely small in Poser. Try scaling the MT down by 100 times or so. It could also be the source obj you are trying to modify is out of scale. Translated back that would cause explosions as well. Also, AM may not be saving the vertices out in the same order. This will also cause explosions. If AM has some optimizing features like compressing vertices and such, tyurn those off.
sama1 posted Sat, 23 December 2000 at 4:54 PM
I did try re-scaling the OBJ file, but I still had the same problem. You may be right about the optimization feature, but I could not find a way to turn it off. I guess I am back to finding another modelling program to make MTs Thanks for the response. Sam
sturkwurk posted Sun, 24 December 2000 at 6:15 AM
Sam, I tried the same thing about a year ago... and never could get it to work.. the best program I've found for morph targets (and I'm not an expert) is Rhino. Doug
I came, I rendered, I'm still broke.
