lordstormdragon opened this issue on Dec 28, 2004 ยท 31 posts
lordstormdragon posted Tue, 28 December 2004 at 7:30 AM
Here's the old contours using the terrain + water plane method... I stripped off the textures to see what was going on with the actual geometry, and as you can see, there's not much there. Not worth the billions of polys spent on 2048x2048 sized terrains...
Message edited on: 12/28/2004 07:32
lordstormdragon posted Tue, 28 December 2004 at 7:37 AM
lordstormdragon posted Tue, 28 December 2004 at 7:38 AM
lordstormdragon posted Tue, 28 December 2004 at 7:48 AM
lordstormdragon posted Tue, 28 December 2004 at 7:56 AM
Attached Link: http://www.renderosity.com/messages.ez?ForumID=107&Form.ShowMessage=2056128
And it brings me to this mess... An unrendered screenshot, but does anyone (who cares) think this new water looks better, or worse, or anthing like that? I'm kinda stuck on this image, haven't done anything else in Bryce except my Cereal picture for awhile... Any feedback would totally rock. The link goes back to my last WIP #3, which also wasn't the first WIP #3 for this bastard scene... Thanks for looking, of course!CrazyDawg posted Tue, 28 December 2004 at 9:09 AM
LSD, if i may suggest something that may help you with the waves you are having trouble with. If this fails it the old undo button:) try using some erosion on them, around 512 or less.
I have opinions of my own -- strong
opinions -- but I don't always agree with them.
tjohn posted Tue, 28 December 2004 at 9:36 AM
tjohn posted Tue, 28 December 2004 at 9:38 AM
dvd_master posted Tue, 28 December 2004 at 9:46 AM
I like the new water plane, but it doesn't seem realistic. If that's not what you're going for, then you should use it, because it looks really nice.
Incarnadine posted Tue, 28 December 2004 at 12:33 PM
The new water is much better, just need to cut back on the bump noise a bit IMO.
Pass no temptation lightly by, for one never knows when it may pass again!
lordstormdragon posted Tue, 28 December 2004 at 2:27 PM
DVD, I'm kinda going for a fantastical quality to it all... Similar to some of my older images, but with a darker, more angry (read : orange) feel.
Incarnadine, tell me if the AA render is still too crusty for ya? I was going for turbulence, really...
This render took about 5 hours, which is fully HALF of what it took before, so I think that my optimization process is working well... I forgot to take the actual SPRAY terrains (separate from the water terrains, and different mats) in the previous renders.
Is this any better? (Also, I changed the POV and increased the render size slightly, so a half-as-much-as-before render time is more like 4/10ths or so, some ratio like that...)
Message edited on: 12/28/2004 14:29
Incarnadine posted Tue, 28 December 2004 at 3:55 PM
I would try a just a little more cut back. looking good.
Rayraz posted Tue, 28 December 2004 at 4:13 PM
The big waves work great around the stone cliffs but I would brush them away on your heightmap in more open area's like in the 1st render. Then maybe for the bumpmap, lower the scale of the texture a little and lower the bump height a little too?
(_/)
lordstormdragon posted Tue, 28 December 2004 at 10:40 PM
Thanks for all of your help and ideas... Incarnadine, did you mean by cut back the same thing that Rayraz means? I admit, upon looking at it, that the big wave look a little TOO big compared to the splash waves and spray... Thanks again for your critiques, everyone. I keep looking at Hobbit's painted waves and banging my head against the wall.
Vile posted Tue, 28 December 2004 at 10:41 PM
Very cool I love it so far!
lordstormdragon posted Tue, 28 December 2004 at 10:46 PM
My main goal is to get the waves to look as smooth as the sky, not so easy... Perhaps I will take an hour out tonight and try to model the waves using NURBS (Rhino, for me), it might be cool..
Claymor posted Wed, 29 December 2004 at 1:16 AM
I think the terrain you're using now gives the water a much better sense of flow and direction. I wonder if doing gaussian edges might smooth down the outside ridges while keeping some better height in around the pillar. I'd say you're definately moving in the right direction.
lordstormdragon posted Wed, 29 December 2004 at 1:18 AM
Aye, I used Gaussian edges, also I clipped the square so that they aren't square on the bottoms... Thanks for the support, Claymor.
Rayraz posted Wed, 29 December 2004 at 4:51 AM
try using bryce's terrain editors fractals for waves, it can work quite well.
(_/)
lordstormdragon posted Wed, 29 December 2004 at 4:54 AM
Aye, I've tried many techniques and just spent three hours attempting to create physical waves in Rhino (with the actual rock spire models in their correct places and whatnot), but to no avail... I'm just gonna have to let this one go and focus on materials and scaling... There's really no way to make the water "hit" the rockwork. In Bryce, it has to be faked. I may revert to some amount of postwork on this one, yet...
Incarnadine posted Wed, 29 December 2004 at 7:47 AM
Actually upon looking at it somemore I would lower the height of the wave terrain a bit as well. What I had meant was to cut back on the noise/bump texture on the water.
As a suggestion, duplicate the water terrain, adjust its height to greater than that of the initial one and lower it relative to the initial one. Put a frothy material on the new one and a smoother water on the older one. (This is an excellent technique for getting more mat zones into a terrain but it should work for water too.)
Richard
Message edited on: 12/29/2004 07:48
lordstormdragon posted Wed, 29 December 2004 at 7:50 AM
Incarnadine posted Wed, 29 December 2004 at 7:55 AM
Interesting, I'll have to take a look at this.
Rayraz posted Wed, 29 December 2004 at 9:14 AM
Looks interesting! how does it look with a textured render?
(_/)
lordstormdragon posted Wed, 29 December 2004 at 9:24 AM
Not any better, alas it's still rendering but my tests suck. I think I'll put this one down, Ole' Yeller style, for a while and focus on something else until I figure out NURBS water... These terrains just aren't looking how I wanted...
Rayraz posted Wed, 29 December 2004 at 9:26 AM
Do you think you could send me the displacement map of this new wave texture? I'd like to fiddle around with it a bit :)
(_/)
lordstormdragon posted Wed, 29 December 2004 at 9:31 AM
Sure, but it's at 2048x2048. Give me your email, I'll send it over... OR I could just post it here? It's only like 10MB or whatever...
Message edited on: 12/29/2004 09:34
lordstormdragon posted Wed, 29 December 2004 at 9:37 AM
Message edited on: 12/29/2004 09:38
Rayraz posted Wed, 29 December 2004 at 9:41 AM
Thanx, I'll see if I can do something nice with this :)
(_/)
Rayraz posted Wed, 29 December 2004 at 11:29 AM
(_/)
Rayraz posted Wed, 29 December 2004 at 11:40 AM
(_/)
