Lz2483 opened this issue on Dec 28, 2004 ยท 13 posts
Lz2483 posted Tue, 28 December 2004 at 1:37 PM
kuroyume0161 posted Tue, 28 December 2004 at 2:06 PM
n-gons? If the windows are 'holes' punch through a single polygon making it have more than four vertices, that might cause the problem. Poser does not really support them (but even CL has released figures with objects that have n-gons - go figure).
off.
-- Bjarne
Stroustrup
randym77 posted Tue, 28 December 2004 at 2:42 PM
Have you tried it with the Poser 4 renderer?
ockham posted Tue, 28 December 2004 at 2:51 PM
Usually this sort of thing is just as bad in both versions. Poser just HATES facets with concave sides, and a punched window is almost guaranteed to involve some concave sides. Poser tries to bridge over the inturned edges, which gives those "bracket" thingies. Too bad, because it's a pretty house!
randym77 posted Tue, 28 December 2004 at 2:59 PM
Remember that issue that Marforno was having? It was caused by L-shaped polygons, I think. His models look great when you render with the P4 renderer, but you get weird artifacts in the window corners when rendering in Firefly.
Lz2483 posted Tue, 28 December 2004 at 3:17 PM
radym77, You were right, it renders fine with the P4 render engine. But does anyone know why firefly creates this problem? After all, isn't firefly supposed to be an upgrade? Not to bash CL or anything, but what are the differences in the two engines? Anybody know of any links or threads that would help?
Little_Dragon posted Tue, 28 December 2004 at 3:18 PM
Triangulating the mesh might help. Of course, it might also make things worse.
ockham posted Tue, 28 December 2004 at 3:19 PM
Little_Dragon posted Tue, 28 December 2004 at 3:27 PM
P5's Firefly renderer is derived from the Tempest render engine used in PiXELS 3D. It's a completely different render engine that the old P4 scanline renderer.
I find it amazing that the CL team got it to work in Poser at all. It wasn't really designed to handle meshes this small ....
Khai posted Tue, 28 December 2004 at 4:14 PM
Attached Link: http://www.renderosity.com/messages.ez?Form.ShowMessage=1895179
there is an answer.. those are caused by N-Gons (poly's with more than 4 sides). if you have a modeling program, (and the inclination), goto the corner of each window and connect the corner vertice to another with an edge. this will "fix" that corner. it's a better method than tri'ing the model.. (cuts the polycount from the tripled amount to just what you need)... I did a mini tute for tS, (applicable in any program that exports to OBJ format), here - http://www.renderosity.com/messages.ez?Form.ShowMessage=1895179 hope that helps explain the problem.. the poser 4 render is slightly more forgiving than firefly.. but not much... hth!Little_Dragon posted Tue, 28 December 2004 at 4:25 PM
You'd only need to triangulate the problem areas, I think, but I agree.
Little_Dragon posted Tue, 28 December 2004 at 4:27 PM
the poser 4 render is slightly more forgiving than firefly.. but not much... It's certainly more forgiving with regard to double-sided polys. :/
Lz2483 posted Wed, 29 December 2004 at 8:29 AM
Great! This is just what I needed to know. The original mesh is not mine but I'm going to go play around and see what I come up with. I only hope the original author will respond to my e-mail and find this thread. Thanks, L8tr
