Forum: Bryce
Subject: Question re: Hierarchies
keppel opened this issue on Dec 27, 2000 ยท 6 posts
keppel posted Wed, 27 December 2000 at 7:29 AM
I'm new to Bryce but have been using Rhino for a little while. I imported a robot I had created in Rhino and had some difficulties in grouping objects. A couple of related questions. Can I view and select an imported models (.obj) individual components in a list before ungrouping them? When I ungroup the model parts what is the best way of selecting numerous small parts all to be textured the same (ie. the joint bolts or finger and toe elements). For this picture I found the easiest way was to gradually cut the elements away and paste them into a new file until I had all the 'like' parts together then group them before bringing in the next group? One last question - when assigning a different colour to each group of elements am I limited to the 25 that appear in the family box, and if not how do I go about increasing the group number. Thanks in advance Shane
My Renderosity Store
Virtual Furnishing
My Portfolio
fredramsey posted Wed, 27 December 2000 at 8:24 AM
I don't know about Rhino, but it has been my experience importing objects into Bryce that I can Control-Shift-Click on the object and select individual pieces, without ungrouping the original. Perhaps you can use this to create your own groups. Hope this helps.
3ddave44 posted Wed, 27 December 2000 at 10:33 AM
Keppel, also if you hold down the ctrl key and hold down the mouse over your model you get a pull down list of every object under the mouse at that moment and you can select from that list. Very handy - I used Bryce almost a year before knowing that and it has made things a lot easier. Then as fredramsey says if you add the Shift key to the mix you can select multiple pieces. The shift key works as a toggle between adding to your current selection or subtracting. Dave
KenS posted Wed, 27 December 2000 at 2:20 PM
Attached Link: http://www.chemicalstudios.com/tutorial/tut3/index.html
Actually theres a much easier way to do this, select the small arrow and goto select mesh it will list each and every mesh. He's a tutorial on doing just that.
keppel posted Thu, 28 December 2000 at 4:23 AM
Thanks for the tips. Checked your site out FastTraxx. Found the Poser2Bryce tutorial informative as well. Shane
Virtual Furnishing
My Portfolio
KenS posted Thu, 28 December 2000 at 2:55 PM
Glad to hear you found it useful : )
