arcady opened this issue on Jan 05, 2005 ยท 8 posts
arcady posted Wed, 05 January 2005 at 7:21 PM
Attached Link: http://www.runtimedna.com/viewed.ez?download_id=9258
Truth has no value without backing by unfounded belief.
Renderosity
Gallery
SamTherapy posted Wed, 05 January 2005 at 7:39 PM
Simplest way is to use the Ambient Color, if your object has a different material for the inside. Otherwise, you can always shove a spotlight or two in there. Works in P4 and Pro Pack, too.
ockham posted Wed, 05 January 2005 at 9:35 PM
ockham posted Wed, 05 January 2005 at 9:50 PM
operaguy posted Wed, 05 January 2005 at 11:44 PM
I believe it is possible to put a light inside an object. Then you can control everything, including color, direction, intensity, etc. Make the camera itself not visible so the actual 'camera' does not show in the shot, only the light. ::::: Opera :::::
arcady posted Thu, 06 January 2005 at 3:48 AM
Renderosity
Gallery
semidieu posted Thu, 06 January 2005 at 5:06 AM
you could also try to put a volumetric light in it... That way, you could see lights going out from the mouth and eyes of the pumpkin...
raven posted Thu, 06 January 2005 at 6:37 AM
Try using ockham's Ashara lightball Python script ( search freestuff for 'Ashara's Lightball') to make a light ball which you could scale down to put into the pumpkin. That's what I'd do.
