peevee opened this issue on Jan 06, 2005 ยท 9 posts
peevee posted Thu, 06 January 2005 at 4:48 AM
Marque posted Thu, 06 January 2005 at 4:58 AM
Not sure on the camera, you may need to check your settings on the output size, that would be under the render. If you want to change the preset way you start up go to preferences under edit. Choose launch to preferred state and I also have previous checked. Do this after you have set up the character the way you want it to always open. Sorry no coffee yet and my eyes aren't open. Hope I haven't confused you. I took everything out so mine opens empty and I don't have to get rid of something before I start. Marque
Tilandra posted Thu, 06 January 2005 at 5:28 AM
Hawke posted Thu, 06 January 2005 at 5:35 AM
Your rendering problem is caused by a mismatch between the render size and document window size. Have a look in 'Window - Document Window Size' These dimensions need to be copied into your render window size in render options. Once you have copied them over tick the 'maintian aspect ratio' box, then you can scale your final render size as you like without cutting of any of the image.
peevee posted Thu, 06 January 2005 at 5:52 AM
thanks for replying in such a short time, everybody! Peevee
Spire posted Thu, 06 January 2005 at 8:59 AM
Just as an extra tip, one thing I do after telling Poser to render in a new window is to make sure the pic will be in the same proportion as my display, and then lock it. That way, no matter what size output you want, all you have to do is change one value and the other will adjust along with it.
SamTherapy posted Thu, 06 January 2005 at 9:29 AM
Additional to Tilandra's tip about setting the way Poser starts, here's a useful one from Dr Geep. See those 9 little dots on the screen? The UI dots? Click on one of 'em. This will save your preferences so that when (not if) Poser screws up and doesn't open a document window, you'll be able to get it back by clicking on the dot. A couple of things to note: When a dot is "empty" or unused it will be the same colour as the Poser background. When it has something saved in it it will be silver grey. When it's been selected it will be bronze. To clear a dot, Alt Click on it.
Bobbie_Boucher posted Thu, 06 January 2005 at 11:27 AM
Hawke posted Thu, 06 January 2005 at 4:38 PM
Hey - there's a 'match document window' button! - who'd have thunk it :P I never noticed it and have been typing it in manually for ages lol
