Subject: Flickering
Robo2010 opened this issue on Jan 07, 2005 ยท 4 posts
Robo2010 posted Fri, 07 January 2005 at 1:15 AM
In Poser (Using 5), what causes a mesh to flicker. I notice when in good position cam view, all is ok. But move a little bit this way or that way or forward just an inch with the mouse, and all of a sudden your view is covered in something messy. Then move the mouse a inch more, and all is clear again. I have seen this a lot, even from purchases here. Then in animations I have done, the flickering accures. Shadows dissapear then inch more, they appear. I have an obj file imported that I have made, no texture yet, and I see this flickering and also viw blockage. What is that caused from?
operaguy posted Fri, 07 January 2005 at 3:04 AM
Attached Link: http://www.renderosity.com/messages.ez?Form.ShowMessage=2052752&Form.sess_id=26953496&Form.sess_key
This is a known problem, robo, that's the bad news. The good news is...there is a solution. Here is the solution: scale up! Note that the first post of the thread above contains a link to a prior thread, as well. ::::: Opera :::::
operaguy posted Fri, 07 January 2005 at 3:08 AM
Now I do have to say....I have never encountered 'flicker' when moving the camera in the pose room. It normally is only seen in animations and in close up single renders. Are you sure there is no prop suspended in mid-air and you are accidentily moving the camera "through" it? ::::: Opera ::::
Robo2010 posted Fri, 07 January 2005 at 9:22 AM
No..the prop I have is on ground and not Mid Air. I have seen this a few times. I will get pics. When this accurs again.
