Subject: Duplicate objects or props in poser
MarkusVogt opened this issue on Jan 08, 2005 ยท 5 posts
MarkusVogt posted Sat, 08 January 2005 at 3:57 PM
Is is possible to duplicate an object or a prop in Poser like its possible in Bryce (f.e. STRG+D)? This would be very helpful, not everytime nescessary to load a new one from the library & adjust again. I didnt found this option in Poser.
Thanks & have a nice weekend
Markus
dbowers22 posted Sat, 08 January 2005 at 4:13 PM
Select the grouping tool from your editing tools. It the square with a dot in the middle. Select the prop you want to duplicate. Click "Add All" in the grouping editor. Click "Create Prop" in the grouping editor. Give your new prop a name. Exit the grouping editor. X, Y, and Z translate your new prop to put it where you want it.
SamTherapy posted Sat, 08 January 2005 at 5:11 PM
MHV - if you're referring to "instancing", no you can't.
thefixer posted Sun, 09 January 2005 at 4:50 AM
You can for instance take V 3 and then fully clothe her and then save the whole thing in your "character" laibrary by using the + sign in the library pallette. Doing that means you don't have to go through clothing and conforming again. This is in P5 I don't know about earlier versions. I think you can do the same with props. You can certainly make a prop and add it like that so you can use it over and over. Don't know if this is what you're asking so Apologies if it isn't.
Injustice will be avenged.
Cofiwch Dryweryn.
JohnRickardJR posted Sun, 09 January 2005 at 7:49 AM
Have a look for the GPA python scripts in the Free Stuff here. That includes a script for duplicating props and another for duplicating figures - very useful.
