Marque opened this issue on Jan 12, 2005 ยท 19 posts
Marque posted Wed, 12 January 2005 at 1:38 PM
Says CD holder and looks like it's got room for two content cd's but only got the app CD....is this right? Thanks, Marque
Marque posted Wed, 12 January 2005 at 1:50 PM
Even says in the folder there is supposed to be more than one cd, anyone know what's up with this? Thanks, Marque
markmartinracing posted Wed, 12 January 2005 at 1:54 PM
You should have got 3, the app and 2 content cd's. You'll need to contact e-on, good luck.
Marque posted Wed, 12 January 2005 at 1:57 PM
Sigh, this really sucks. Thanks, Marque
Marque posted Wed, 12 January 2005 at 4:52 PM
Tried contacting them and got stuck in a maze of faq's. Does anyone from Vue EVER come in here? Marque
nanotyrannus posted Wed, 12 January 2005 at 5:02 PM
Not often enough to solve your problem, when you click on the tech support button select vue 4 professional (from the pulldown) and "an issue not listed here" (from the second pulldown). Ignore all the common solutions and click "continue to knowledge base" and do a search (for anything, it doesn't really matter). Once you get to the next screen ignore everything the search brought up and click on "contact a technician". This finally brings you to a form you can fill out, usually they answer the next day. I know, it's the most useless annoying system I've ever seen for getting an actual technician's help but it's what they've got.
krimpr posted Wed, 12 January 2005 at 6:04 PM
Their system for customer support is inadequete. Their products are good, but their lack of accessability will be their undoing.
Marque posted Wed, 12 January 2005 at 6:44 PM
Thanks will try again. Marque
Marque posted Wed, 12 January 2005 at 6:46 PM
Put missing cd's in the search of the knowledge base and got this.... Query: select *, match(message_synopsis, message_content) against('missing cd's') as score from message where (message_inknowledgebase = 1 and message_categories like '%Support~Vue 4 Professional~an issue not listed here%') and (match(message_synopsis, message_content) against('missing cd's') >= 0.707) order by score desc limit 0, 2 You have an error in your SQL syntax. Check the manual that corresponds to your MySQL server version for the right syntax to use near 's') as score from message where (message_inknowledgebase = 1 an
nanotyrannus posted Wed, 12 January 2005 at 6:49 PM
Weird, did you try looking for a different item? (since it doesn't matter anyway, the only purpose to doing the search is to get to the page that has "contact a technician" on it) it looks like a general fault with their web page.
Marque posted Wed, 12 January 2005 at 6:52 PM
Got through and sent the email, thanks nano for the tip on getting to the email. Marque
dueyftw posted Thu, 13 January 2005 at 3:13 AM
~Their system for customer support is inadequete. Their products are good, but their lack of accessability will be their undoing.~ They don't even have their own forums. You have to come to other websites to find anyone who is using Vue. I never seen such a poorly supported product, excluding Windows that is. Dale
kwanou posted Thu, 13 January 2005 at 5:23 AM
Attached Link: http://www.e-onsoftware.com/Support/Forum/
quote: *They don't even have their own forums.*Well it seems that you did not get far enough...
Only have to be e-on registered to access it.
Plenty of people in there...
At least you don't get to pay $125 to get support, such as in other companies.
Cheers.
Message edited on: 01/13/2005 05:25
Marque posted Thu, 13 January 2005 at 7:43 AM
I am registered and I did go to the forum and leave a message but no answer yet. Marque
svdl posted Thu, 13 January 2005 at 3:54 PM
I think MySQL hiccuped on your search term, it contained an apostrofe, which is used as the string delimiter in many SQL dialects, including MySQL. Lousy server side scripting, it should strip illegal chars from the search string before submitting the query to MySQL... Alas, not an unusual mistake in PHP driven sites.
Marque posted Thu, 13 January 2005 at 5:45 PM
Went into the forum and asked for help and one of the mods there is requesting that I get my missing cd's. I figured if I hit everything someone would help. 8^) Marque
jwhitham posted Thu, 13 January 2005 at 5:59 PM
"I think MySQL hiccuped on your search term, it contained an apostrofe, which is used as the string delimiter in many SQL dialects, including MySQL. Lousy server side scripting, it should strip illegal chars from the search string before submitting the query to MySQL... Alas, not an unusual mistake in PHP driven sites." Oh yeah, this is what broke it: "('missing cd's')" three single quotes (apoostrophes), unterminated string! Amazing isn't it, I've accidentaly hacked into the servers of two of the worlds biggest software companies recently - not going to say who, I value my freedom - by innocently typing terms like that!
Marque posted Fri, 14 January 2005 at 10:37 AM
This is what I got in reply when I contacted support at e-on. Hi Marque, It is really surprising that you haven't got the 2 extras cds... To contact someone of our support team, go on the page http://www.e-onsoftware.com/Support/ and then click on one of the button in th page, in your case "contact a sales representative" or "contact a technician". You will be able to write someone. But as it is a problem of ordering, I think you should contact orders@e-onsoftware.com and explain you problem, let an adress, and they surely will send you "new" cds. Regards, Matt
Marque posted Fri, 14 January 2005 at 12:04 PM
My cd's are on their way and I really appreciate Cecile for sending such a nice email. Vue is back on my buy and recommend list. Marque
