KyReb opened this issue on Jan 15, 2005 ยท 12 posts
KyReb posted Sat, 15 January 2005 at 1:42 AM
My figure Library has several V3s. Victoria 3 Victoria 3 SR1 Victoria 3 SR2 Victoria 3 MM Can I go ahead and hit the Minus on some of these without causing any damage??
Bobbie_Boucher posted Sat, 15 January 2005 at 1:56 AM
Attached Link: DAZ3D
I don't know what Victoria 3 MM is. The other ones are actually old versions of Vicky 3. The newest one is Vicky 3 SAE. You can get her for free at DAZ3D now.SWAMP posted Sat, 15 January 2005 at 2:11 AM
Well if Vic 3 SR2 is your most current Vic you can delete the Vic 3 and Vic SR1. The Victoria 3 MM is the Cr2 that came with the "head sculpt pack" for those special inj/rem to work properly...you DON'T want to delete that one. SWAMP
zvzulndr posted Sat, 15 January 2005 at 7:19 AM
On the same note, how do you handle crosstalk with the V3 SAE? every thing I have tried has failed: I either lose the morphs or don't get them. Yes I have read the FAQs (confusing and I am very computer literate). This crosstalk problem is making Poser much less enjoyable. Is there a NULL CR for V3 SAE or M3?
SWAMP posted Sat, 15 January 2005 at 8:58 AM
Attached Link: http://www.nerd3d.com/catalog/index.php?cPath=1&sort=2a&page=2
Nerd's crosstalk fixer Cr2..... It comes with a little mini-tut on it's use.Message edited on: 01/15/2005 09:01
RHaseltine posted Sat, 15 January 2005 at 9:16 AM
If you have the International Beauties set you need the update for the Head Sculpture pack that will give you a Victoria 3 SR2 MM file to replace your Victoria 3 MM: there isn't an MM version of the new Victoria 3 SAE yet.
SWAMP posted Sat, 15 January 2005 at 7:47 PM
Or you can do what I did... Just transfer the head morphs from the MM cr2 to the standard Vic cr2 with MorphManager and be done with it (took all of 20 sec).
Strixowl posted Sat, 15 January 2005 at 8:45 PM
Oh great. I guess I missed something. I've got Victoria 3,Victoria 3 SR1,Victoria 3 SR2,even Victoria 3 MM, but just now heard of SAE. What is Victoria 3 SAE? Is it worth down loading? What's differant? It sounds like it has some problems (above), does it? Where at DAZ is it? Thanks in advance for your response(s)
Bobbie_Boucher posted Sat, 15 January 2005 at 9:10 PM
Victoria 3 SAE is the latest version of Victoria 3. Everyone gets Vicky 3 for free now. Yes, it's worth downloading.(As stated above), you want to get her, and delete your Vicky SR1 & SR2.
RHaseltine posted Sun, 16 January 2005 at 9:00 AM
V3 SAE has the expression morphs in the figure file, so you don't have to make a trip to the pose library (and there are some extras compared to the original), it has scalable hands as in Aiko 3 and the elemental and it fixes a misspelled channel introduced with SR2 (HdPhilipino). There is an update on the DAZ Updates page, in the Support menu in the page header.
Strixowl posted Sun, 16 January 2005 at 12:26 PM
Big thank You, Bobbie_Boucher & RHaseltine :-)
Bobbie_Boucher posted Sun, 16 January 2005 at 9:40 PM
Anytime.
