ElOsoPolar opened this issue on Jan 17, 2005 ยท 4 posts
ElOsoPolar posted Mon, 17 January 2005 at 5:15 PM
I made some hair in Poser5 then saved the character. Other times, I have been able to toggle show populated after I had loaded my character...but now, I cannot. For some reason, I cannot edit the hair either. How can I fix this?
Plutom posted Tue, 18 January 2005 at 10:21 AM
Hmmm,have you tried the stock hair styles to see if you have the same problem? Next question, where are you saving the hair and character? Another problem could be that your RAM is not clearing itself after you've been using it for some time. Try a reboot (clears RAM cache)and see if that helps. PlutoM
ElOsoPolar posted Tue, 18 January 2005 at 12:24 PM
No luck with the reboot. Now I may have made a mistake saving the character. I saved the character into the new figures folder. Saved it as a "Whole group" with all the clothes and props and hair. I had done it before and it worked fine. I did overwrite it once or twice, and that's when the problem happened.
Plutom posted Tue, 18 January 2005 at 5:24 PM
I'm finding out that with hair involved, everything slows down real fast. Since I'm new to this game, I'm experimenting with just the Hi Res Judy 5 model, then I can save her and the hair in the hair gallery and pull the hair out when necessary--still working that room as well as the "CLOTH" room! I think I'm going to cheat and paste all characters, props VUE 5 scenery into PSP and build my scene there. errg Plutom
