darkness_02 opened this issue on Jan 19, 2005 ยท 5 posts
darkness_02 posted Wed, 19 January 2005 at 10:04 AM
You imagination is your only limitation.
Check out Dark Design for freebies for your own artwork.
alexsm posted Wed, 19 January 2005 at 10:51 AM
Whay you do the big flash on the top imege ? this teke half on image ...
draculaz posted Wed, 19 January 2005 at 11:04 AM
the plane's okay, although I'd work a bit more on the wings (try metaballs), look up some reference pictures on airplane wings. i like the amount of detail on the guns and so on. the walker i can't see very well because of the blast. drac
TobinLam posted Wed, 19 January 2005 at 11:57 AM
I know its your plane, but the inlets should be a lot smaller. If you look at the size of intakes on fighter jets compared to the size of the exhaust you will find the area of the inlet seems to be just a little bit larger than the area of the exhaust. The side laser pods should blend into the body as well. I like how you got away with not modelling the body of the walker and replacing it with an explosion.
ysvry posted Wed, 19 January 2005 at 5:23 PM
i liked the guns better at the end off the wings that looked more balanced
