Subject: P4 fem hi poly replacement chest now at freestuff
Mason opened this issue on Jan 01, 2001 ยท 8 posts
Mason posted Mon, 01 January 2001 at 3:14 AM
This file is a cr2 with the new chest info embedded as a new grouping. It overrides the data in your obj and does not require an obj install. It will not erase your obj. Instructions come with on how to move this to another figure. Only attempt this if you are an advanced user. I added about 10 MTs with it. If used, older p4 fem chest MTs will not work. The b****s have been tesselated and the n*****s are cleaned up with higher detail added. Will work with any figure that currently uses the p4 fem chest including eve hybrids. Again, this is at geocities so you'll have to right click and do a save as or save target as.
wyrwulf posted Mon, 01 January 2001 at 3:21 AM
Thanks for all your contributions, Mason. I consider you as one of the pioneers of Poser with Morph Manager, combined figures, and all the rest you have given to the community.
Greyskin posted Mon, 01 January 2001 at 6:00 AM
Anyone Else having trouble with the zip? I get about a 66k zip and thats all. Greyskin
Krel posted Mon, 01 January 2001 at 8:02 AM
....hey Mason, didn't realize you were the author of Morph Manager (I use it all the time!; I know, I'm stupid). Pay no attention to that long and arduous thread about your posting. Your work is excellent. Thanks for posting this, although I can't seem to get it at all..........I'll keep trying....... Krel
joeyb posted Mon, 01 January 2001 at 9:58 AM
I'm a little confused. How does this P4 hi poly replacement compare to the Eve figure? I've heard/read that Eve is more detailed and better "animated" than the P4 fem figure. Is this type of work headed in that direction, more or less detail, better detail, or just different?
Helen posted Mon, 01 January 2001 at 11:29 AM Online Now!
I am glad to see your work is back up. Although it is something I personally probably won't have a use for it will be appreciated by many... As the show once said 'Different Strokes'. :)
Senior MarketPlace Tester
If anyone sees a mind wandering aimlessly around..... It is mine.  I want it back.
Mason posted Mon, 01 January 2001 at 2:44 PM
joeyb - I believe the eve figure seperates the chest into two 3 regions making left and right regions part of the collar bones. It still uses the original p4 mesh. This mesh is the standard p4 mesh only it has twice the polygons around the bs. Kind of like adding a higher poly count face to p4 fem which is what Vickie is. This way the bs can be modelled better without huge jagged polygons. Use it only if you need higher detail in the fem chest area.
Krel posted Tue, 02 January 2001 at 5:41 AM
I got the download and tried it......it really is well done, Mason! Thanks! Much smoother-looking breasts......... Krel
