Subject: PNG to RSR???
Starkdog opened this issue on Jan 21, 2005 ยท 6 posts
Starkdog posted Fri, 21 January 2005 at 1:26 AM
Ok, I made a ton of MAT poses for a project I am working on. I want to make my product compatible with Poser4 and PP (I have Poser5). Since the script I have for MAT poses saves it as a PNG + a PZ2, how do I convert the PNG to an RSR file? Somebody mentioned P3DO to me, but I cannot find where in the P3Do interface where to do such things, just edit thumbnail sizes, etc. What should I do now??? Thanks, -The Starkdog
Helgard posted Fri, 21 January 2005 at 1:30 AM
The PNG to RSR is a plugin for P3Do. do a search in freestuff under the makers name, or go to yarp's artist page and look at his freestuff, it should be there. This is if I rememeber correctly.
Your specialist military, sci-fi, historical and real world site.
Helgard posted Fri, 21 January 2005 at 1:32 AM
Attached Link: http://www.renderosity.com/freestuff.ez?Form.Contrib=yarp&Topsectionid=0
The plugin is here
KarenJ posted Fri, 21 January 2005 at 1:43 AM
Attached Link: http://koti.mbnet.fi/~ilaripih/MPEHome/
*Since the script I have for MAT poses saves it as a PNG + a PZ2...* It sounds like you have a script for saving MAT poses from the P5 material room, maybe the Netherworks script? You will also need to make sure those MAT poses are compatible with P4, as well as producing a .rsr file. If you're not using any P5-specific material features, then just load the MAT pose into MAT Pose Edit 3 (link attached) and save as P4 version.
"you are terrifying
and strange and beautiful
something not everyone knows how to love." - Warsan Shire
Starkdog posted Fri, 21 January 2005 at 3:45 AM
Karen1573 and Helgard, Thanks for the quick feedback. Yes, I am using Netherworks script. All I did was edit the PZ2 from 5 to 4.01. I will check out the MAT Pose Edit(I think I downloaded this already???). I regards to P3DO, I will check out what Yarp has. I did find an RSR to PNG utility in the freebie section. I will also give that a try. Thanks again for the quick responses. -The Starkdog
Belladzines posted Sat, 22 January 2005 at 8:16 AM
Mat Pose Edit has the option of making the mats compatible for p4 and pp i think.. thats what i use to do my mats. and i use poser 5 to create. p3do is a great help to do rsr files... i was given that link by a friend.
