camelot77 opened this issue on Jan 23, 2005 ยท 5 posts
camelot77 posted Sun, 23 January 2005 at 12:46 PM
I have created a hair model for poser with all its morphs, I was wondering how do I put it all together and turn it into a figure or even a hair prop, I noticed all the other hair creators use either figures or hair props, whats the benefits also of turning it into a figure?
kuroyume0161 posted Sun, 23 January 2005 at 1:08 PM
Hair props are just regular props. When you place the hair prop in the Hair folder, it is assumed to be parented to the Head of the figure. Some hair has 'handles' and multiple body parts in order to be more flexibly shaped. In these cases, it needs to be a figure (props cannot have 'handles' or body parts). Unless there is an overwhelming need to make the hair into a figure, I wouldn't. It's work and should only be done as necessary.
off.
-- Bjarne
Stroustrup
camelot77 posted Sun, 23 January 2005 at 1:37 PM
thanks for your help, I still have to figure out how to get the prop into the hair folder, when I try to save it there it comes up empty.
kuroyume0161 posted Sun, 23 January 2005 at 2:18 PM
off.
-- Bjarne
Stroustrup
SirLancelot posted Sun, 23 January 2005 at 5:04 PM
Thanks I should have realized that, I am building the hair on top of a head prop so I forgot :) thanks for your help
