kromekat opened this issue on Jan 02, 2001 ยท 3 posts
kromekat posted Tue, 02 January 2001 at 8:54 PM
what am I doing wrong? - I export the figures from Poser 4as 3ds into Bryce 4 - I slect the figure and select the texture map applied parametric and am getting little white 'seams' appearing along the sides of the legs and down the arms/neck etc! Also, I dont always get a smooth model after using the edit mesh option in Bryce! Any help would be appreciated!
Adam Benton | www.kromekat.com
ackbar posted Tue, 02 January 2001 at 10:22 PM
Use .obj when you export. It will be larger, but it will be smooth from the start and the texture maps will fit.
kromekat posted Wed, 03 January 2001 at 5:56 AM
Thanks I will give that a go!!
