Forum: Poser Technical
Subject: how to ?
Black Rain opened this issue on Jan 26, 2005 ยท 3 posts
Black Rain posted Wed, 26 January 2005 at 10:44 AM
Hi, need a little help :) i'm doing my first attempts to make "Figures" for Poser and i have a little problem. i made a mechanical object with, in my mean, parts to move indipendently from the main. my problem is this: once made the character, if i move (rotate) the portion its parent is affected too - is there a way to fix this? thanks in advance
PhilC posted Wed, 26 January 2005 at 10:53 AM
This will be down to editing the joint parameters which is going to be a little difficult to explain without seeing the figure. However for many mechanical models you do not want the one part to affect another when rotating. If this is the case select each body part and go to Object/Properties and turn off the bend option.
Let us know if that gives you the results you require.
Black Rain posted Wed, 26 January 2005 at 12:38 PM
ahh - shame on me! it was under my eyes :) works!!! THANKS :) i had to apply some adjustments in the join editor too, to refinish :) thanks a lot Phil!!!
