Forum: Photography
Subject: Seeking advice on lenses for a D-SLR newbie :)
Wivelrod opened this issue on Jan 26, 2005 ยท 5 posts
Wivelrod posted Wed, 26 January 2005 at 6:38 PM
Hey all.
Earlier this week I popped into the local camera shop with the intention for getting some passport photos, and ended up leaving not only with said photos, but a Canon 20d with the 18-55mm lens!! That was one pricey lunch break!!
Way back in the distant past I used to have a Film SLR, but much of what I learnt I've forgotten (and from what I remember anyway I pretty much made it up as I went along :P ). I've not used that camera since 1995. The year before last I got a Sony 717 and my interest was re-kindled and I found my way to this little corner of the world wide web :)
Anyway, I'm finding it very hard to decide what set of lenses I should obtain. Comparing the 18-58mm that I have to my old 717, I have a wider wide angle, but the max zoom is shorter. Now I didnt often use the max optical zoom on the Sony 717, except when using a close up lens (Hoya +4) for macro work. Dpreview.com lists the sony as having a 38mm-190mm lens. So compared with the old camera, I'm loosing a fair bit of telephoto performance.
So any suggestions on what a good second lens would be (may help to take a brief look at my gallery to see what images Ive produced with the old sony 717)?
Some ideas that I've had:
Any advice to a D-SLR newbie is very much appreciated!
randyrives posted Wed, 26 January 2005 at 8:51 PM
Wow, that was one expensive lunch. lol Hard choice, looking at your gallery, seems like you are split between sceneics and close up. You might want to check out the Sigmas zooms with Macro. One good one lens from Canon is the 70-200 F4 L lens. This would be a good companion for the 18-55. The L lens is a pro level lens that is super sharp and is on my want list. If I was starting over again, I think I would have gotten this instead of the 75-300 IS.
LostPatrol posted Wed, 26 January 2005 at 8:58 PM
Attached Link: http://www.renderosity.com/messages.ez?ForumID=12379&Form.ShowMessage=2091679
Look at this thread; it may help as this has been discussed
The Truth is Out There
DJB posted Thu, 27 January 2005 at 1:58 AM
Sounds like you are at the same place as me on this one. Yes...see that thread. Was talking about same thing.
"The happiness of a man in this life does not consist in the absence but in the mastery of his passions."
Wivelrod posted Thu, 27 January 2005 at 3:44 AM
Aha, I didnt realise you'd veered off into lens talk, was all about bodies last time I checked :D Thanks gang, I'll redirect to there. Cheers :)
