ibassplayer205 opened this issue on Jan 26, 2005 ยท 12 posts
ibassplayer205 posted Wed, 26 January 2005 at 10:22 PM
Attached Link: http://www.renderosity.com/photos/MSG2/Message2092831.jpg
the link is to a sample image used to render using the same set up.
MoonGoat posted Wed, 26 January 2005 at 10:54 PM
Do you have soft shadows or any other shadow-dimishing feature on? Is the brightness of your monitor set at an appropriate level? MoonGoat (Second question was a joke)
lordstormdragon posted Thu, 27 January 2005 at 12:24 AM
Do you have global shadows "ON" in the Skylab? Without this set to on, you will have no other shadows...
xenic101 posted Thu, 27 January 2005 at 12:40 AM
What I would do is...
Check that shadows (and soft shadows) is turned on in the sky lab. Turn off shadows for all the lights. Then turn shadows (yes, make them soft) for one or two of the lights off to the side.
It'll render alot faster and that many soft shadows being cast are probably washing each other out.
Is the picture linked to, a bryce render? If it is, make sure that the ground is accepting shadows. Or you might have shadows covering the entire ground.
lordstormdragon posted Thu, 27 January 2005 at 12:47 AM
I guess there's something even MORE important going on here. The whole point of using light domes is to not NEED softshadows, as the light dome creates the softest shadows as it's main purpose. If you had one or five lights, then maybe soft shadows would be important, but it's not. And it's just gonna drive your render times way, way up. Forget about them and try it, see how it looks!
vasquez posted Thu, 27 January 2005 at 2:01 AM
How much is the ambience of the floor?
pogmahone posted Thu, 27 January 2005 at 2:05 AM
I've just woken up, still feeling a bit groggy.......but to me the attached image appears to have shadows :^|
Claymor posted Thu, 27 January 2005 at 3:08 AM
Looks to me like either: Cast shadows is off on the bike while self shadows is on. OR more probably... The ambience is too high on the ground texture.
dan whiteside posted Thu, 27 January 2005 at 7:01 AM
I'm with LSD - turn SS off or set the value really low.
lordstormdragon posted Thu, 27 January 2005 at 7:50 AM
Aye, not to be a jerk about it, but the only reason TO use a light dome is because you don't feel like using SS. Or vice versa. Sometimes SS drives render times into oblivion, and without premium settings SS isn't much better than a light dome can get... Although light domes hit objects from multiple angles, they are generally a soft-shadows technique or a "global illumination" technique. You honestly don't need 73 of them really, but it's your render! Try it all, learn as much as you can...
pauljs75 posted Thu, 27 January 2005 at 6:36 PM
Also remember that when using a light dome you have to control the brightness using the color setting of the light. That might be part of it too.
ibassplayer205 posted Thu, 27 January 2005 at 7:27 PM
