Subject: How To Constrain Window Aspect Ratio -- Permanently?
moushie opened this issue on Jan 27, 2005 ยท 5 posts
moushie posted Thu, 27 January 2005 at 3:17 PM
Ive asked this before, but nobody had an answer. Maybe there isnt one. Maybe Ill be lucky. In Poser 4 I like to maintain a 4:3 window aspect ratio, e.g. 320 by 240. This can be done via WindowDocument Window Size and checking the box Constrain Aspect Ratio. But it doesnt stick once the file is closed. Every time I open Poser, or open an existing file, or even Revert within a file, the box is unchecked. This loses a lot of time. Is there a way to set aspect ratio for good?
Message edited on: 01/27/2005 15:18
raz posted Thu, 27 January 2005 at 3:55 PM
sure! after you set your aspect ratio, tick the Constrain box. THEN go to edit (at top toolbar), general preferences, tick launch to preferred state, then click the set to preferred state button in that window. Now when you open your POSER the winder will be set at the size you last selected. HOWEVER. I have noticed that even when ticking the constrain aspect ratio thingy, when you resize the document window it has a 1-3 variance of being exact accurate. Nothing that has ever been enough to notice in the render, but ..... I hope I didnt misunderstand your Q.........
moushie posted Thu, 27 January 2005 at 10:55 PM
Maybe I wasn't clear, but thanks. It's not that easy. Saving to prefered state means the window comes up at the right aspect ratio all right when opening Poser -- but the constrained box is now unchecked. So resizing the window with the mouse now upsets the aspect ratio and the box has to be re-checked. How do I constrain it permanently? is the question.
ynsaen posted Fri, 28 January 2005 at 3:33 AM
Unless you have the ability to decompile and recompile the core code, not possible :)
moushie posted Fri, 28 January 2005 at 9:55 AM
OK. Too bad. Thanks.
