Sking opened this issue on Jan 05, 2001 ยท 6 posts
Sking posted Fri, 05 January 2001 at 11:38 PM
I have been mucking around with creature creator and loaded a 3ds model into poser. This is where i get stuck. At the moment the model is just one whole thing. How do i (if i can at all) go about selecting the different body parts for minipulation. Would appreciate any help - Thanks in advance.
JeffH posted Fri, 05 January 2001 at 11:53 PM
Attached Link: http://www.bushi3d.com
There's a whole lot to do to make it work in Poser. Try reading the tutorials at www.bushi3d.comJeffH posted Fri, 05 January 2001 at 11:56 PM
Attached Link: http://skyscraper.fortunecity.com/tyrell/769/poser.html
Also, download the posertutorial.zip at the bottom of this page: http://skyscraper.fortunecity.com/tyrell/769/poser.htmlSking posted Sat, 06 January 2001 at 12:05 AM
Hi JeffH, Thanks for the speedy response. You have been a huge help in pointing me in the right direction. Thanks and most appreciated.
Mason posted Sat, 06 January 2001 at 2:39 AM
I've made characters from Creature Creator myself. Its do-able. One thing I had to do was tesselate it on level to make it look good.
Vethril posted Sat, 06 January 2001 at 1:13 PM
Attached Link: http://www.renderosity.com/gallery.ez?ByArtist=Yes&Artist=LadyLight
Take the 3DS file, into Poser, then export it as an obj file. Then, open UVMapper, and bring it in. In UVMapper, there is a function that will allow you to select parts of the creature, and make it a group. Not sure how your going to write your cr2 file for it, but if you've got a 1 piece mesh, and are good with cr2's, you can break it down to a multipart figure. Good luck! =)
