Subject: Creating new models/characters
barrowlass opened this issue on Feb 05, 2005 ยท 10 posts
barrowlass posted Sat, 05 February 2005 at 4:56 AM
I've made a couple of characters which I like and want to use again. How do I put them into the libraries so I can just click to insert them into a scene? I've attached a screenshot.
My aspiration: to make a decent Poser Render I'm an Oldie, a goldie, but not a miracle worker :-)
Gallery
Freebies
Music Vids
xantor posted Sat, 05 February 2005 at 7:33 AM
You can rename a pz3 to be a cr2 but when you load it in it uses the window size from the file (which probably isn`t a bad thing).
barrowlass posted Sat, 05 February 2005 at 7:53 AM
never done that before - is it just a case of straightforward renaming (changing the suffix) or is there something else to be done? It sounds much too simple for Poser ;-)
Gallery
Freebies
Music Vids
xantor posted Sat, 05 February 2005 at 8:07 AM
You do just change the suffix. You can then move the file into a library and use it like any other library file.
barrowlass posted Sat, 05 February 2005 at 8:09 AM
wow! I thought there was some weird and wonderful process to go thru. here goes then! thanx a lot guys - x
Gallery
Freebies
Music Vids
geep posted Sat, 05 February 2005 at 8:37 AM
... or you could just do this ... ... unless it is not a figure ... then ... just add it to your props library. cheers, dr geep ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
thefixer posted Sat, 05 February 2005 at 10:48 AM
Do what geep says, it's by far the easiest way. If you have stuff on the figure like clothes and hair etc. you will get a message about saving as a group. Say yes and then it will be saved complete. I do it this way all the time when doing a story line for instance. Make and clothe the character and then save complete to the library to be used as and when I please and the when I've finished with it just click on the "negative" mark and it's gone!
Injustice will be avenged.
Cofiwch Dryweryn.
barrowlass posted Sat, 05 February 2005 at 12:22 PM
thank you so much - I've just done it - can't believe it's so simple! This forum has been such a help to me - I wouldn't have had a clue otherwise.
Gallery
Freebies
Music Vids
raelislington posted Sat, 05 February 2005 at 9:20 PM
blinks I've been trying to figure out how to do this for a while...I can't believe it's that simple! I love you guys.
danamongden posted Thu, 17 February 2005 at 10:48 PM
Oh my God!! I've also been trying to figure this one out for some time. I've even been looking for a tutorial on it for the last couple of days, but I couldn't find one. I was about to post asking after someone, but I figured someone would have already asked at one point. Sure, I'd seen the "Add To Library" button before, but I always figured that was for "install third party files now" or something. Maybe I'm just the slow one, but that really ought to be in the Poser FAQ.
