Subject: help with clothing please
Jen opened this issue on Jan 06, 2001 ยท 4 posts
Jen posted Sat, 06 January 2001 at 6:38 AM
I want to save the the clothing & hair off thornes fairys to my clothing and hair directory so I can use them on his other fairys. How can I do that so they will pop into place automatically on a different thorne fairy? Thanks in advance :)
Krel posted Sat, 06 January 2001 at 7:42 AM
If you save the hair to the hair library it will automatically be saved as a "smart prop". Just select the hair, then save to the library as a new preset. As for clothing, that's a little more complicated but if it's a conformimg figure then it can be conformed to any figure you want once saved. If the clothing is a prop (not a figure) you must first set a parent (i.e., if it's a top you need to parent it to the figure's chest), then save it to the prop library. When prompted to save as a "smart prop" answer yes. Krel
Jen posted Sat, 06 January 2001 at 1:09 PM
Thanks Krel. Ok I saved the thong for example as a smart prop after making the hip the parent. I then tried to apply it to the same model but it was way to big. Am I missing a step somewhere?
Krel posted Sun, 07 January 2001 at 6:48 AM
Well........some settings are not necessarily saved to the library, I believe any XYZ scale changes do not get saved but I'm not sure.....if the figure is standard size then the prop should fit....if you've scaled the figure then you have to scale the prop...... Krel
