Subject: Poser 5 can't find files
Triarius opened this issue on Feb 09, 2005 ยท 4 posts
Triarius posted Wed, 09 February 2005 at 8:12 PM
I remember this problem happening with an earlier version, but I don't remember what caused it. I have my default figure set to V3. When I launch Poser, it asks me to locate the geometry file. When I try to inject a morph, it does the same thing. What is causing this, and how do I fix it?
Lucifer_The_Dark posted Thu, 10 February 2005 at 8:17 AM
It sounds like you've moved something & the references are messed up, have a look at CorrectReference or CorrectReference Pro on hogsoft.com as this will probably be able to fix it for you. Make sure the !Daz folder that contains the morphs is in the main poser5 runtime or it can't find them.
Windows 7 64Bit
Poser Pro 2010 SR1
Triarius posted Thu, 10 February 2005 at 10:11 AM
So there is something about DAZ stuff that requires it to be in the main runtime?
Lucifer_The_Dark posted Thu, 10 February 2005 at 10:34 AM
Only what's in runtimelibraries!Daz, for some strange reason Poser5 doesn't see those files unless you have that folder in the main Poser5 runtime, everything else can go into whichever runtime you want. It's probably some sort of bug in the ReadScript function that causes it but no-ones looked into it that I know of.
Windows 7 64Bit
Poser Pro 2010 SR1
