Subject: which v3 do you use to create a pose file for sale?
wotdoin opened this issue on Feb 11, 2005 ยท 8 posts
wotdoin posted Fri, 11 February 2005 at 1:11 PM
Do I have to use the blank version to make poses or face files for sale or just the V3 sr1? Is the blank V3 just for morphs? I am a bit confused about the blank version. Thanks Debbie
Tashar59 posted Fri, 11 February 2005 at 2:57 PM
The blank is more like a dress dummy. You are behind in versions. I would suggest going over to Daz and updating or just get the new free base. It's V3-SAE.
KarenJ posted Fri, 11 February 2005 at 3:29 PM
To make face files you would need to use the normal version as you will be injecting expressions and/or morphs. But for making poses I use the blank version to make sure my saved poses don't include any morphs. I have also experienced some weird stuff when saving poses and then using them on the different SR versions of Vic. So be sure to save, then load V3_SAE or whatever and verify that you don't get any error messages. And if you're using P5, you'll need to edit the begining of the .pz2 file to change the version number, or P4 users will get an error message.
"you are terrifying
and strange and beautiful
something not everyone knows how to love." - Warsan Shire
Ardiva posted Fri, 11 February 2005 at 8:53 PM
Karen...what do you mean by: "If you're using P5, you'll need to edit the begining of the .pz2 file to change the version number..." (?)
hauksdottir posted Fri, 11 February 2005 at 10:22 PM
You get a message that says something like "Poser has detected a newer than expected version number, but will attempt to open the file anyway". Click "ok" and it opens just fine. But if you don't know about the message, you might not think it will work. If the message isn't there, no worries. Now, some stuff is P5 only... materials with displacement maps or stuff for the P5 family... so you probably don't need to edit the version number. Carolly
KarenJ posted Sat, 12 February 2005 at 6:10 AM
At the beginning of every .pz2 file, if you open it up in a text editor, you'll see this: { version { number 4.01 } But if it was saved with P5, it will say "number 5.1" or similar. You need to just change it to 4.01 to avoid error messages popping up in P4 or PPP.
"you are terrifying
Ardiva posted Sat, 12 February 2005 at 10:16 AM
Ahhhhhh! Many thanks for the info, Karen. Really nice to know little things like that. :)
wotdoin posted Sun, 13 February 2005 at 8:23 PM
thanks for all of your help with this I did not realize that there was a newer version of V3 so I better hop on over to daz and pick it up. Debbie
