JamieReid opened this issue on Feb 11, 2005 ยท 13 posts
JamieReid posted Fri, 11 February 2005 at 11:19 PM
Can anyone help explain the P node a little better? How it works, maybe an example of it in use. This may be a repost - sorry if is.
nruddock posted Sat, 12 February 2005 at 12:13 AM
JamieReid posted Sat, 12 February 2005 at 1:28 AM
Thank you, that's what i thought but I can't get the effect I'm looking for. I want a snapshot of a figure appearing to fade from the bottom up. I tried pluging a P node (x=0,y=1,z=0) into a color ramp (white to black) and pluged that into the tranceparancy (set to 1)? However this fades too quickly and only the feet fade. Changing the y to a higher value only makes the fading transistion sharper not higher up on the figure. How do raise the overall fading height?
operaguy posted Sat, 12 February 2005 at 3:48 AM
bookmark. the complexity and power of the material room captivates me. ::::: Opera :::::
ynsaen posted Sat, 12 February 2005 at 7:08 AM
Remember that the material is only going to apply as far along the figure as that material zone applies -- and is only going to apply to the material zone.
nruddock posted Sat, 12 February 2005 at 11:31 AM
To determine the values to use you need to know the minimum and maximum Y coordinates of the figure, call these Ymin and Ymax.
As you want the transparency to go from 0 to 1, the values for the offset and scale factor are then as follows :-
Scale factor = (Ymax - Ymin)
Offset = -Ymin
Don't forget to set the Edge and Falloff to 0
JamieReid posted Sat, 12 February 2005 at 12:42 PM
Ahh,yes. That's exactly what I was looking for. Thank you very much, nruddock, for the mini-tutorial.
Ajax posted Sat, 12 February 2005 at 9:37 PM
View Ajax's Gallery - View
Ajax's Freestuff - View
Ajax's Store -
Send Ajax a message
Ajax posted Sat, 12 February 2005 at 9:42 PM
Ajax's Store -
Send Ajax a message
Ajax posted Sat, 12 February 2005 at 9:51 PM
Ajax's Store -
Send Ajax a message
operaguy posted Sat, 12 February 2005 at 9:52 PM
fantastic!
Ajax posted Sat, 12 February 2005 at 9:55 PM
Ajax's Store -
Send Ajax a message
JamieReid posted Wed, 16 February 2005 at 1:13 PM
Thank you, too Ajax. It amazing what you can do with the material's room. :)
