cHEESE_GOW opened this issue on Jan 08, 2001 ยท 3 posts
cHEESE_GOW posted Mon, 08 January 2001 at 4:59 PM
I was just reading Renapd's tutorial on how to create Poser clothing, and I was doing fine until it got to the place where you rename the .txt file to .cr2. It doesn't tell you how to, and I can't figure it out. Help would be appreciated.
JeffH posted Mon, 08 January 2001 at 5:14 PM
First you have to be able to see the extensions in WIN9x. Change the setting in Windows Explorer so that all extensions are shown. Then find the cr2 that's named "YourFile.txt", right click on it so the context menu pops up, then choose "rename" and change the extension to "YourFile.cr2". You may get a warning that this will make the file unusable, just ignore it. All of this assuming you're using Windows ;-) -JH.
doozy posted Mon, 08 January 2001 at 7:32 PM
Renaming files on Mac: In the Finder, click on the file's icon, then hit enter (not return). The filename should be hilited then, and you can type there as in any text.
