Forum: Photoshop
Subject: thumbnails?
ninhalo5 opened this issue on Jan 11, 2001 ยท 8 posts
ninhalo5 posted Thu, 11 January 2001 at 12:53 AM
hi i was just wondering if there is a plugin that can make thumbnails easily? or something like "if any one can remember" how compupic created thumbs by full pages. oh just thought of something else is animated gifs possible in photoshop as well? thanx jeff
apesnater posted Thu, 11 January 2001 at 5:27 AM
for the thumbnails check the actions. record your kliks and press play, or you can try acdsee where you can select some images and save as html nd you get one page with thumbnails as links to the original pics. for animated gifs use adobe image ready, no problem. create you frames as layers in photoshop and then open image ready.
Prizm Break posted Thu, 11 January 2001 at 7:44 AM
Hmmm, good info. What are the commands in Image ready once you have all the layers stacked? or is there a special way of saving it?
apesnater posted Fri, 12 January 2001 at 3:30 AM
first you klik on the animatiom Tab (below), then klik on bottom circle button. Then you get a new frame, each frame you can set layers on and off. then save optimized as *.gif.
apesnater posted Fri, 12 January 2001 at 3:38 AM
this is the end result...........:o)
Prizm Break posted Fri, 12 January 2001 at 7:37 AM
Thanks for the great info, Ill try it :)
Sushubh posted Tue, 06 February 2001 at 3:12 AM
Attached Link: http://www.irfanview.com
For making thumbnails u can try Irfan View (http://www.irfanview.com) Cool Software does a lot of other things too
Prizm Break posted Tue, 06 February 2001 at 5:18 PM
thx, ill do that
