Subject: A question to all poser enthusiasts
Uzilite opened this issue on Feb 22, 2005 ยท 78 posts
Uzilite posted Tue, 22 February 2005 at 5:28 AM
Hi, I would just like to know certain information about Poser users in general.
  1. How many of you are still using Poser version 4. Not Pro Pack or Poser 5?
  2. How many of you are using Poser Pro Pack?
  3. How many of you understand the difference between .bum and .jpg format and how to convert the former to the other?
Thanks in advance.
Coleman posted Tue, 22 February 2005 at 5:49 AM
Poser 5+
Arvanor posted Tue, 22 February 2005 at 5:57 AM
Poser 5 only.
If by my life or death I can protect you, I will!
RedHawk posted Tue, 22 February 2005 at 6:02 AM
P4.....but then, I'm still using Win98.....:/
<-insert words of wisdom here->
SAMS3D posted Tue, 22 February 2005 at 6:27 AM
I use Poser 4 still, but own have have used PoserPro, Poser 5 and just bought Poser 6. Also, I understand the difference between bum and jpg Sharen
Message edited on: 02/22/2005 06:28
hauksdottir posted Tue, 22 February 2005 at 6:43 AM
ProPack on the Mac and Poser 5 on the PC.
Yes, I know the difference in bump maps and formats, but why convert unless you enjoy jumping through hoops or need to use an older item?
Message edited on: 02/22/2005 06:44
FlyByNight posted Tue, 22 February 2005 at 7:04 AM
Yes. No. Yes.
FlyByNight
Porthos posted Tue, 22 February 2005 at 7:34 AM
No No Yes
MS Windows 7 Home Premium 64-bit SP1
Intel Core i7-2600 CPU @ 3.40GHz, 12.0GB RAM, AMD Radeon HD 7770
PoserPro 2012 (SR1) - Units: Metres , Corel PSP X4 and PSE 9
eirian posted Tue, 22 February 2005 at 7:34 AM
Poser 5 only. Yes, I know the difference and how to convert, but as P5 doesn't use .bum files neither do I :-)
gaz170170 posted Tue, 22 February 2005 at 7:37 AM
Poser 4 Pro and Poser 5....whatever does the job easiest
kuroyume0161 posted Tue, 22 February 2005 at 7:58 AM
Yes. Yes. Yes.
 -- Bjarne Stroustrup
Booker5 posted Tue, 22 February 2005 at 7:58 AM
  1. Yes. 2. No. 3. Yes.
RHaseltine posted Tue, 22 February 2005 at 8:05 AM
Yes No Yes
Farside posted Tue, 22 February 2005 at 8:08 AM
P5 only Never bothered with ProPack Yes, can convert .bum files
Jay7347 posted Tue, 22 February 2005 at 8:11 AM
P5 and hopefully P6 soon. Yes...I can convert -jay
xantor posted Tue, 22 February 2005 at 8:17 AM
I use propack and poser 5.
Tyger_purr posted Tue, 22 February 2005 at 8:20 AM
P5 only. Understand the concept of bum vs jpg, but never needed to convert.
My Homepage - Free stuff and Galleries
Netherworks posted Tue, 22 February 2005 at 8:25 AM
1-heck no. 2-yes 3-absolutely Sounds like your considering dropping "direct" p4 support. I've thought about it too.
Kalypso posted Tue, 22 February 2005 at 8:26 AM Site Admin
P4 and P5, just ordered P6. I know the difference and for what it's worth, I've gone through my entire runtime changing ALL my .bum to .bmp files, then compressed them into .jpg's and use them with MAT poses for P4 because .bum files take up too much space. Unfortunately I cannot apply them manually in P4 so that's a pain because some items I have to edit (props, cr2's etc.)
caulbox posted Tue, 22 February 2005 at 8:36 AM
P5 Only. If anyone is using mPower Tools (or the earlier Picaview) from ACDSee, you can just right-click a BUM file and convert to JPG.
Uzilite posted Tue, 22 February 2005 at 8:45 AM
Hey Thank you all for participating. I am considering of dropping support for .bum files. Just as Kalypso mention they are large thus translates to bigger archives and longer downloads.
kuroyume0161 posted Tue, 22 February 2005 at 8:56 AM
The problem with .bum file size is that they are uncompressed .bmp files. But, the other problem is that compressing .bum files (normal map) is not a good thing. At least lossy compression compromises data integrity in this case (remember these aren't 'images' per se, but data maps). I agree, though, that .bum files should become extinct. The issue here is that support must remain as long as they exist in content. What should be done is a permanent conversion to height map (bump map) with links fixed in the Poser file.
rockets posted Tue, 22 February 2005 at 9:03 AM
I use Poser4 and I do know the difference and know how to convert them. I very seldom use bump maps though (I take them out) because they slow down render time.
My idea of rebooting is kicking somebody in the butt twice!
Simderella posted Tue, 22 February 2005 at 9:07 AM
Pro Pack (have p5, rarely use it - won't be able to use p6, I have win me) I know how to convert .bum files.
RawArt posted Tue, 22 February 2005 at 9:22 AM
It would be sweet if an update was made for P4 to allow it to use jpegs instead of those .bum files. That would make product development a ton easier too.
momodot posted Tue, 22 February 2005 at 9:30 AM
I use Poser 4 or ProPack (which ever I can get to run) most of the time because of the quick start up and ease in applying textures. I use Poser 5 for major pieces of work for the nodes and the Face Room mainly but often even there I render in Poser 4 using Poser 5 since I don't like the Firefly render and use it only when I need special node stuff. My other problems with Poser 5 are the instablity and the hassle of doing simple texture stuff using the Materials Room. So there, despite my basic preferance for P4 I have gone ahead and pre-ordered P6 blind. Why can't they stop being coy and show us what we are actually buying??! If you are vending stuff can't you just package both .jpg and .bum for textures given that everyone around here but me has a buttload of memory.
Tyger_purr posted Tue, 22 February 2005 at 9:41 AM
pardon me if i oversimplify things but given the choice between letting out bits of positive information vs. letting out all the postive information at onece and listening to all the negative feedback (i.e. "thats crap, why didn't you include ______? ", "I'm not buying if cuz you didnt include _____?") I wouldn't tell all until I had to either.
ArtyMotion posted Tue, 22 February 2005 at 10:00 AM
If you are vending stuff can't you just package both .jpg and .bum for textures given that everyone around here but me has a buttload of memory. BUM textures are enormously HUGE and don't compress well. They add a great deal to the file size and increase download times exponentially. It's best all the way around to not include BUM files in the product package.
PapaBlueMarlin posted Tue, 22 February 2005 at 10:16 AM
P5 going on P6 I prefer JPG bumps since they are smaller in file size. I definitely also want them plugged into the right node...
lemur01 posted Tue, 22 February 2005 at 10:19 AM
P4... got P5, use it as a bookend... won't get P6 until it's proved to work and do all it says it will. Jack
Ona posted Tue, 22 February 2005 at 10:26 AM
  1. I use P4 because some of my favourite figures cannot be loaded on P5 and the P5 to Vue4Pro exports do not work on my PC. 2) Only P4, no Pro Pack. 3) I understand the difference between jpg and bum.
Arien posted Tue, 22 February 2005 at 10:35 AM
  1. P5, waiting for P6 2) never bothered 3) I know the difference, haven't done conversions in ages.
My store
dlk30341 posted Tue, 22 February 2005 at 10:38 AM
Poser 5 .....will be using Poser 6 once I get it :)
TT posted Tue, 22 February 2005 at 10:51 AM
  1. Still Poser4 (the render time ) got just P5/P6
  2. Never used
  3. Yes
    IMHO merchants should still support P4 but include only the .jpg insted for .bum and a tought for the .png preview images, why include them on packages as both propack and P5 reads .rsr.
"I like my species the way it is."
pokeydots posted Tue, 22 February 2005 at 10:54 AM
  1. no 2. yes 3. yes
Poser 9 SR3  and 8 sr3
Processor Type:  AMD Phenom II 830 Quad-Core
2.80GHz, 4000MHz System Bus, 2MB L2 Cache + 6MB Shared L3 Cache
Hard Drive Size:  1TB
Processor - Clock Speed:  2.8 GHz
Operating System:  Windows 7 Home Premium 64-bit
Graphics Type:  ATI Radeon HD 4200
•ATI Radeon HD 4200 integrated graphics
System Ram:  8GB
taco posted Tue, 22 February 2005 at 11:28 AM
P4 only. Might upgrade to 6 when all the reports/complaints are in!
No pro pack
I do convert the .bums but it's a tedious and annoying job! Glad you are considering dropping them!!!
Message edited on: 02/22/2005 11:29
Fredy posted Tue, 22 February 2005 at 11:48 AM
  1. No 2. Yes - P4Pro only (6 ordered) 3. Yes
thefixer posted Tue, 22 February 2005 at 11:53 AM
Poser 5 only, soon to be 6 and as P5 doesn't bother with BUM's [I think], I never bothered finding out about them!
Injustice will be avenged.
Cofiwch Dryweryn.
pakled posted Tue, 22 February 2005 at 12:08 PM
P4, with Propack, heck P3 as well..;) know there's a difference, but haven't played with it. No plans to even go to 5, much less 6..;)
XENOPHONZ posted Tue, 22 February 2005 at 12:18 PM
No.
No.
Yes.
P6 as soon as it arrives in my mailbox.
Feel free to drop support for .bum files. At some point, everyone should stop using Windows 3.1, too.
It'll taper off with time.
Something To Do At 3:00AM
SnowSultan posted Tue, 22 February 2005 at 12:20 PM
I'm still using Poser 4 for creating Free Stuff (like MORs and seam guides), but I use DAZ Studio for everything else. I hope merchants will start supporting D|S when it reaches 1.0. I might upgrade to Poser 6 after seeing what others think of it. No, I never used PP. Yes, I have used and converted BUMs in the past, but they got so large that I only use them when absolutely necessary. D|S uses JPGs like PP and P5, so I prefer using them there. Thanks, SnowS
my DeviantArt page: http://snowsultan.deviantart.com/
I do not speak as a representative of DAZ, I speak only as a long-time member here. Be nice (and quit lying about DAZ) and I'll be nice too.
KateTheShrew posted Tue, 22 February 2005 at 12:27 PM
I use ProPack, have P5 - didn't reinstall it after the last HD crash, no intention of ever getting P6 - don't need all those bells and whistles for what I do, ProPack works fine for me and doesn't require a screen resolution that I can't read. Yes, I know how to convert bump maps, but I seldom use them since I don't render in Poser to begin with.
Smoovie posted Tue, 22 February 2005 at 12:27 PM
I use both 4 and 5, and I understand the concept of bum vs jp
gladiator posted Tue, 22 February 2005 at 12:29 PM
Poser 5 only
pizazz posted Tue, 22 February 2005 at 12:46 PM
YES NO YES
RobbyBobby posted Tue, 22 February 2005 at 12:56 PM
Poser 4 No Pro Pack Know the difference...just a pain to find the jpegs to convert to bums with all the stuff that I tend to buy.
Lucifer_The_Dark posted Tue, 22 February 2005 at 1:22 PM
Poser5 only here, it's so long since I had to convert a jpg I've forgotten how :D
Windows 7 64Bit
Poser Pro 2010 SR1
Tashar59 posted Tue, 22 February 2005 at 1:41 PM
P5, only use P4 to test what I make. No, jumped right to P5. Yes. I too have toasted all the .bum in all my files. As a dial-up user, I hate those unneeded file types.
Netherworks posted Tue, 22 February 2005 at 2:00 PM
wusamah, in that case you only have to include the .jpgs and leave .bum-version references in the P4 version of the files. If you give all of your bumpmaps the same suffix (like "BUM" in caps), before using your package the customers would only need to load each of those to the ground plane once to convert to bum files.
Marque posted Tue, 22 February 2005 at 2:31 PM
Poser 4, Poser 4 pro pack, Poser 5 and just ordered Poser 6, and yes I understand the difference and know how to convert. Marque
RNKarenER posted Tue, 22 February 2005 at 2:40 PM
I use poser 4 with PP, I dont understand poser 5.... sad but true. I wouldnt know a bum if he came up to me on the street!
Richard T posted Tue, 22 February 2005 at 2:46 PM
ProPack mainly and sometimes, Poser 5. I know about jpegs and how to convert .bum files.
odeathoflife posted Tue, 22 February 2005 at 2:46 PM
1.Poser 5 only ( I have poser 4 but it is not installed I format my drives so much that once I just never put it back in as I hadn't been using it)
2.look to # 1 and insert propack
  1. sure
Message edited on: 02/22/2005 14:47
♠Ω Poser eZine Ω♠
♠Ω Poser Free Stuff Ω♠
♠Ω My Homepage Ω♠
www.3rddimensiongraphics.net
PilotHigh posted Tue, 22 February 2005 at 2:58 PM
On a Mac Poser 4 only (6 ordered) I routinely convert jpgs to bums.
ChuckEvans posted Tue, 22 February 2005 at 3:14 PM
(1) I use P4 (2) Never used PP (3) I know how to convert JPGs to BUMs (ugh!) Note: P6 pre-ordered (whatever that means for you)
nruddock posted Tue, 22 February 2005 at 3:15 PM
No. Very rarely, as I have a lot of content outside my PP Runtime. Yes.
Jackson posted Tue, 22 February 2005 at 3:56 PM
I still use ProPack mostly. And "Yes" to number three.
ariannah posted Tue, 22 February 2005 at 4:07 PM
P5 on a Mac while trying to be patient awaiting P6.
I dare you, while there is still time, to have a magnificent obsession. --William Danforth
Kristta posted Tue, 22 February 2005 at 4:19 PM
I got started with Poser when version 5 was already out. I've never used 4 or Pro Pack. I've got 5 and have pre-ordered 6. I understand the differences between a .bum and .jpg but don't know how to convert bum to jpg. Kristta
Jim Burton posted Tue, 22 February 2005 at 4:33 PM
Yes No Yes
kayjay97 posted Tue, 22 February 2005 at 4:41 PM
no yes yes
In a world filled with causes for worry and anxiety...
we need the peace of God standing guard over our hearts and minds.
Jerry McCant
spudgrl posted Tue, 22 February 2005 at 7:12 PM
Poser 4 I know the diffrence between the 2 formats. I know how to convert one to the other.
thorntoa posted Tue, 22 February 2005 at 7:12 PM
no yes yes
Allan Thornton
Pony10 posted Tue, 22 February 2005 at 8:02 PM
Yes No No The only features that might get me to "upgrade" are the ability to run scripts and the cloth room. So far I am not good enough to worry about the scripts and use external programs for the cloths. I understand that you can do some nice stuff with hair as well. Still trying to decide on P6. Seems like a lot of money if not all my models/work will work in it.
Sasha_Maurice posted Wed, 23 February 2005 at 1:45 AM
P5 only.
cyberscape posted Wed, 23 February 2005 at 6:37 AM
1 - Use P4 and P5. Been using/learning P5 a lot more lately. 2 - Used PP a few times and uninstalled it. It runs too slow considering the lack of features compared to P5. 3 - Know the difference and how to convert. Quite often I'll make my own bump maps (for products that don't have them) if I plan to do any close-up renders.
AMD FX-9590 4.7ghz 8-core, 32gb of RAM, Win7 64bit, nVidia GeForce GTX 760
PoserPro2012, Photoshop CS4 and Magix Music Maker
...and when the day is dawning...I have to say goodbye...a last look back into...your broken eyes.
TrekkieGrrrl posted Wed, 23 February 2005 at 9:11 AM
P5 exclusively nowadays. Will wait and see P6 in action before I get that, but I'm sure I will eventually change to that :o)
WadeTripp posted Wed, 23 February 2005 at 11:19 AM
I use only p5 exclusively.
Uzilite posted Thu, 24 February 2005 at 4:47 AM
So it seemed that the consensus is to drop .bum files which will translate to smaller packages and faster download. Additionally I've created a tutorial page for those you may still not understand the conversion from .bum to .jpeg. How to bump I very much love you all for participating. Again thanks.
karanta posted Fri, 06 May 2005 at 11:03 AM
1.) 5 + 6 2.) No 3.) Yes
My Renderosity Store
dallas40m posted Sat, 07 May 2005 at 2:27 AM
Pro Pack, but mainly Daz Studio. Rarely touch poser anymore. :D
Warmest Regards,
Dallas
dorkati posted Tue, 10 May 2005 at 12:24 PM
I used Poser 5 and now Poser 6 , but I know the difference between bum and jpg.
nomuse posted Tue, 10 May 2005 at 12:37 PM
The consensus agrees with laboratory data (aka, gallery renders made with my products); if you don't include BUM files, P4 users won't use bumps. But it also appears that if you DO include BUM files, many P4 users still won't use bumps. So I concur. Throw the BUMs out! Besides -- anyone who uses P4 is going to be either someone who has been using Poser for a while, or someone who has gotten used to figuring out how to maintain compatibility in a rapidly changing (notice I didn't say "advancing") computer world. Aka, they are the most likely Poser users to be able to figure out a bump-map conversion. Laetia and I were just discussing this issue, and our general slant seems to be that the cleanest way to maintain P4 bump compatibility is to provide Bump Poses in the download; MAT poses that do nothing but inject P4-style BUMs. With the cross-compatibility of PP jpegs and P5 displacment/gradient nodes, it then becomes possible to have a single MAT pose that serves the other versions of Poser.
ItWasNotAvailable posted Tue, 10 May 2005 at 1:32 PM
I tested this by releasing P5 versions only and there wasn't much difference in sales. P5 alone sold as good as paks containing both versions. let's face it: how many people used P3 when P5 came out? We are now at P6 and they already talk about P7. I think it's time to move on, especially since P5 and above grants better quality in renders...lev
obm890 posted Tue, 10 May 2005 at 2:07 PM
What about including a MAT pose which applies the BUM automatically, but as a jpg? I saw this method in a tut somewhere and it works a treat: In P4 you make a .BUM file by manually applying the texture whateverTex.jpg. Then you rename that .BUM extension to .BMP, open it in an image editor (it'll be a weird greenish relief image) and save it as whateverBump.JPG. Then make a MAT pose (just for P4 users) that'll apply that jpg as the bump map. PP users can apply the regular texture image jpg as their bump. It means P4 users are still supported, The downloads are barely affected (it's a jpg, not a BUM) and they have a one-click application, they don't have to jump through hoops to convert anything. Ob
mommastacie posted Tue, 10 May 2005 at 2:08 PM
I never use BUMs. I have P4 Artist & most of the time it likes to thnk it's PP... crazy thing won't load P4 versions no matter what I try.. it must have closer workings to PP than P4. So buh-bye BUMs. hehehe
Stacie ><>
My RO Gallery
My deviantART
Huggers,
Stacie
Find me at
deviantART
ArtZone
Facebook
My Stores:
Rendo
3D Commune
CafePress
Jean-Luc_Ajrarn posted Tue, 10 May 2005 at 2:52 PM
  1. How many of you are still using Poser version 4. Not Pro Pack or Poser 5? No. 2) How many of you are using Poser Pro Pack? No. 3) How many of you understand the difference between .bum and .jpg format and how to convert the former to the other? Yes.
HandspanStudios posted Wed, 11 May 2005 at 1:12 AM
I still use Poser 4 but I have both P5 and P6. I can convert a .jpg but I prefer not to have to. As a merchant I do package both .jpg and .bum versions.
"Your work is to keep cranking the flywheel that turns the gears that spin the belt in the engine of belief that keeps you and your desk in midair."
Annie Dillard
