Forum: Photography
Subject: jpgs STILL scambled..!!!
jimry opened this issue on Feb 22, 2005 ยท 17 posts
jimry posted Tue, 22 February 2005 at 4:09 PM
Going back to a earlier post here, the 'main' images are still showing 'corrupted'...scrambled'...whatever...I have cleaned out my cache, rebooted, all the normal stuff...and i do not belive it is my graphics card playing up..!!...makes it hard to make a comment...!! any ideas why this is happening?..anyone else lately? regards.. jimbO
Onslow posted Tue, 22 February 2005 at 4:13 PM
Yes it happens to me quite often Jim.
Coloured bands or sometimes - like transparent double image. I am always careful before commenting because of it. Nothing clears it except to return another time.
Message edited on: 02/22/2005 16:15
And every one said, 'If we only live,
We too will go to sea in a Sieve,---
To the hills of the Chankly Bore!'
Far and few, far and few, Are the lands where the Jumblies live;
Their heads are green, and their hands are blue, And they went to sea in a Sieve.
Edward Lear
http://www.nonsenselit.org/Lear/ns/jumblies.html
3DGuy posted Tue, 22 February 2005 at 4:16 PM
I never have that here. Maybe try another browser? Could you link to the image you see corrupted?
What is a friend? A single soul dwelling in two bodies. - Aristotle
-= Glass Eye Photography =- -= My Rendo Gallery =-
jimry posted Tue, 22 February 2005 at 4:25 PM
Not really possible 3D...as it could be ANY image thats scrambled and return to find its ok...then its scrambled again...hit and miss?..yeah...must be a problem with in RR server ?
Message edited on: 02/22/2005 16:27
3DGuy posted Tue, 22 February 2005 at 5:07 PM
well since I have no problems on this side, the RR server seems to be fine. I'd suspect your ISP or modem?
jimry posted Tue, 22 February 2005 at 5:10 PM
other web pages are all fine...no probs...just RR 3D...so, thatsays to me, broadband, ISP is fine.
tvernuccio posted Tue, 22 February 2005 at 7:02 PM
hi jim, kemal just called me on his break while i was reading this. he used to be a computer repair tech and he's pretty good about solving computer problems. he wants to know if you've deleted everything from your temporary internet files? he said if you've done that and you're still have problems, just reply back and let me know. he said there's a couple guys he knows who posted once in the Bryce forum who had the same problem. he said when he gets home he'll try to find that information for you. good luck! :)
LostPatrol posted Tue, 22 February 2005 at 8:43 PM
Never had a problem on here either?
The Truth is Out There
DJB posted Tue, 22 February 2005 at 10:48 PM
There is many threads about this,and each time one of the mods or coords goes to see it,the image is fine. I believe it is just the connection to RR servers gets jumbled on a percentage of hits.I have never had this,but have seen the images screen capped and posted. My suggestion too would be to right click the image if it happens and go to the actual image url shown in the pop up menu you get... You could even try copying the image to your paint program to see if it is scrambled there if it really is an annoyance to you. Just suggestions.
"The happiness of a man in this life does not consist in the absence but in the mastery of his passions."
tvernuccio posted Wed, 23 February 2005 at 3:06 AM
jim, kemal suggests you do delete temporary internet files. then: 1. go to internet options 2. then go temporary internet file settings 3. then try to force internet explorer to check for newer version of stored pages every time internet explorer is started. Also, he says to look at the disk space reserved for your temporary files. it's right there on the same page. he says if it's ridiculously small (like a couple of megabytes), windows screws it up by compressing the images more and more. you wanna have it at 100 or 200 megabytes. i had a problem one time just with RR site. everything was totally screwed up. kemal did the above suggestions and everything worked fine again. hope it helps. good luck.
jimry posted Wed, 23 February 2005 at 3:15 AM
Done all that before Sheila...but thanks. I know about the reserved disc space..I have a 200mb on board...so I upped the space few mths back. as you can see, this is what i get...random....sorry Krystie, to use yours as an example...coud be any image though. Other grpahics on web sites , be it whatever, show up no problems, so, that also tells me its not my cache., although its been cleared out etc...now yer know why I cannot comment on some...and yes.... Krystie is STILL the same today...even though I have done all the above..!!! AARRGGHHHHHH..!!!!
jimry posted Wed, 23 February 2005 at 3:27 AM
Happens in Firefox broswer too...again, other web sites show up ok..AARRGGHHHH
tvernuccio posted Wed, 23 February 2005 at 10:26 AM
hi jim, kemal says he will do some digging in the Bryce forum archives and see if he can find that thread. not sure if that guy was having the same problem or not. sorry for all your troubles....
3DGuy posted Wed, 23 February 2005 at 10:35 AM
Looks indeed like a corrupted jpg. As far as I know IE does not recompress the images if your cache is small, that would mean the images you see would look worse if you view them again (high compression factor). Anyhow. It could be your ISP (or rather the proxyserver/cacheserver they use) that somehow has a problem with RR or has corrupted images in it's cache. In that case there's not much you can do about it. Since it happens in both IE and Firefox, you can pretty much rule our anything browser related.
Onslow posted Wed, 23 February 2005 at 11:24 AM
I get exactly same as Jim - faults looking same as above example on random images. I have tried saving and opening in PSP result is the same. Yet I know others view same image and it is fine and I can return later and the image is fine.
Edward Lear
tvernuccio posted Wed, 23 February 2005 at 11:49 AM
ok guys, do you both have another computer so you can rule out the ISP theory? kemal suggests trying to change browser setting for automatic image resizing and smart image dithering. he says sometimes if either of these get corrupted in windows itself, it can produce scrambled images. in that case, the solution would be to reinstall windows. kemal has an extra video card, and he says if he were the one having these problems, he would just take out his video card and put the other one in to see if that made a difference. what a pain in the butt you guys are having. sorry.
JordyArt posted Wed, 23 February 2005 at 12:28 PM
Wow. I NEVER have bother like this. Although I do find RR is DREADFULLY slow - even when I view other sites at the same time they whizz along and RR plods. (",)
