Azrael00023 opened this issue on Feb 22, 2005 ยท 9 posts
Azrael00023 posted Tue, 22 February 2005 at 4:44 PM
I want to delete the eyes from a character and put in new eyes, yet when i try to delete, it deletes the entire head. Is there a way in Poser 4 to delete a body part without deleting another? Thank you.
SamTherapy posted Tue, 22 February 2005 at 5:04 PM
? Why not just make them invisible?
ghelmer posted Tue, 22 February 2005 at 5:20 PM
yeah then just parent the new eyes to the head
The GR00VY GH0ULIE!
You are pure, you are snow
We are the useless sluts that they mould
Rock n roll is our epiphany
Culture, alienation, boredom and despair
kuroyume0161 posted Tue, 22 February 2005 at 5:42 PM
To fill this in completely - you cannot delete body parts at all, so why even discuss the further refinement thereof? CL should put this information in the Manual. Oh, they did!
off.
-- Bjarne
Stroustrup
Hawke posted Tue, 22 February 2005 at 6:42 PM
Go to the setup room and create two new groups. Doesn't matter what they're called as long as they're not associated with a bone (say 'lefteye2' and 'righteye2' for simplicity)
Add the original 'righteye' and 'lefteye' to these groups respectively using the 'add group' button.
Now delete the original right and left eye groups but keep the ones you just created (left2 and right2)
Now when you return to the pose room you will get a warning telling you some polys are not associataed with a bone - this is a good thing in this case. If you go to 'props' you will see something like 'figure_1 setup' This contains polygons which are not associated with a bone (i.e. the eyes in this) so when you delete this prop - voila - you delete the eyes :) Above is a pic just to prove it.
The above can be useful in other situations if you use your imagination :)
Message edited on: 02/22/2005 18:43
kuroyume0161 posted Tue, 22 February 2005 at 7:36 PM
There's even an easier way, if you don't mind editing a CR2. ;)
off.
-- Bjarne
Stroustrup
Azrael00023 posted Tue, 22 February 2005 at 10:23 PM
Thank you all very much for your help! hmm I wish I understood what goes into a cr2 and how to edit and what for. Truth is, I want to learn, have tried finding tutorials but to no luck. Ive opened them up to read them and try to learn more about them, but I have no idea what to do from there lol.
kuroyume0161 posted Tue, 22 February 2005 at 11:35 PM
A good book that'll at least get you started toward understanding Poser figures and the CR2 file is "Secrets of Figure Creation with Poser 5". It is well organized to remove the fear of creating/editing figures as well as starting to understand how it all works.
You can also visit my site to see the internals of the CR2 file laid out (including a downloadable PDF):
Just a quickie: Usually, but not always, a figure is comprised of a single Wavefront .obj geometry. The .obj file contains groups of non-overlapping polygons. The first part of the CR2 file deals with referencing the .obj file and declaring these groups as 'body parts'. Again, usually, all of the groups are included and defined. You can 'skip' body parts by removing the body part reference from within the declaration, for example:
actor head:5
storageOffset 0 0 0
geomHandlerGeom 13 head
becomes
actor head:5
and the head geometry is not loaded from the .obj file. The head definition, which details the joint parameters and other Poser-related settings, is still there, but the geometry is really 'deleted' as it were - unloaded. Try it with a simple Poser 4 character, making sure to save the file under a different name like "Headless Woman.cr2".
Message edited on: 02/22/2005 23:39
off.
-- Bjarne
Stroustrup
Azrael00023 posted Wed, 23 February 2005 at 1:32 AM
Thank you very much I appreciate the in depth help, because it really really helped me. Again thank you!
