Subject: is there a tut for making glass in poser?
anxcon opened this issue on Feb 22, 2005 ยท 14 posts
anxcon posted Tue, 22 February 2005 at 7:36 PM
i need a tutorial for making glass in poser and cant find its glass for a window, but has a front and back poly so it shows "depth" in the glass and viewable from both sides thanks
Tunesy posted Tue, 22 February 2005 at 9:36 PM
Just white in diffuse and 0.9 in transparency can do ok for a window. You can mess with refraction, highlight, etc if you like. Here's a quick window with only transparency changed to 0.9 (both sides of the window) and the rest default. Pay no attention to the hapless guy falling behind the window.
Tunesy posted Tue, 22 February 2005 at 9:46 PM
...oops. I told ya wrong. That's not quite white. It's the first shade of gray to the right of white in the windows color picker, so almost white. That's what I use more out of habit than anything else.
Message edited on: 02/22/2005 21:46
dialyn posted Tue, 22 February 2005 at 11:06 PM
Attached Link: http://www.renderosity.com/messages.ez?ForumID=12413&Form.ShowMessage=2131713
Take a look at what Catherine is doing...!
anxcon posted Tue, 22 February 2005 at 11:06 PM
id use a bit towards a light blue/green but still cant get the glass to look quite right need to know about refraction n stuff :)
Tunesy posted Tue, 22 February 2005 at 11:18 PM
...don't forget that most of the time the viewer won't actually have a perspective to perceive refraction through a window since you won't usually be seeing part of the object through the window and part of it not through the window. Throw it in if it pleases you though ;)
Dave8 posted Wed, 23 February 2005 at 11:16 AM
refration and reflection
Image Hosted by ImageShack.us the vase it self is not the best but this look looks good on other stuff
Message edited on: 02/23/2005 11:18
anxcon posted Wed, 23 February 2005 at 11:31 AM
so then i need some tuts for reflection/refraction :)
Tunesy posted Wed, 23 February 2005 at 1:12 PM
From your first post: "its glass for a window". In that case you don't 'need' refraction normally. A vase is another story.
Aureeanna posted Wed, 23 February 2005 at 5:44 PM
looks great Dave...care to share how you did it.
Dave8 posted Wed, 23 February 2005 at 6:15 PM
its all out there in freestuff just look for it and adjust as u need to as it does not look to great if u leave it as it is need sleep have no idea what am saying anymore
Dave8 posted Wed, 23 February 2005 at 6:36 PM
if ya can wait till l8er i will send the file to ya
this is 2 props using same settings so it can be used on windows just as good as a vase
Aureeanna posted Wed, 23 February 2005 at 6:41 PM
it's gorgeous! well worth waiting...:>0
