annemarie2 opened this issue on Feb 26, 2005 ยท 5 posts
annemarie2 posted Sat, 26 February 2005 at 7:11 PM
I am trying to render my contest entry for BlueLotus's "Render my daughter" contest. I am having some problems figuring out how to do the image size for the print ready version. This is what she wants: 300 dpi (pixels: 4,200 x 5,100). Final print size: 14" X 17" minimum. Question is...where is the dpi adjustment? Can I do it in poser 4, or do I have to do it in Poser 5? I know how to adjust the window size I just have no idea about the dpi. Any and all help would be greatly appriciated:) Thanks alot!
SndCastie posted Sat, 26 February 2005 at 7:17 PM
in poser 4 when you go into render options you can set your render to render in a separate window and change the size and dpi hope this helps not sure on P5 as don't have it. :O) SndCastie
Sandy
An imagination can create wonderful things
SndCastie's Little
Haven
annemarie2 posted Sat, 26 February 2005 at 7:30 PM
is the dpi below the sizing options? Like it says: Width: Height: Resolution: Is the dpi the resolution?
SndCastie posted Sat, 26 February 2005 at 7:36 PM
Yes the dpi is the resolution that it will be printed at. it is normally at 72 just change it to 300 :O) Make sure you click the little box for rendering in a separate window that opens up the size and dpi to change it. SndCastie
Sandy
SndCastie's Little
Haven
annemarie2 posted Sat, 26 February 2005 at 7:37 PM
Thank you so much :) :) :)
