Forum: Carrara
Subject: Chamfer Box
Exyled opened this issue on Mar 02, 2005 ยท 3 posts
Exyled posted Wed, 02 March 2005 at 8:38 AM
How do you create a chamfer box like you can get in 3d Studio Max. I like easy solutions if at all possible. Thanks in advance, Shaun McKinnon
Hoofdcommissaris posted Wed, 02 March 2005 at 8:59 AM
Make a rounded box in the spline modeller. Remember the value you put for the bevel (if you want round bevels). Make it as deep as it is wide and high. Make a section on the front point. Add front bevel and back bevel with the same values as the corners. Presto!
TOXE posted Wed, 02 March 2005 at 9:38 AM
Another method, create a cube in the vertex modeler, leave it as carrara have generated (or use +- if you need more or less value of chamfer), then add a smooth. -TOXE
