Foxseelady opened this issue on Mar 03, 2005 ยท 4 posts
Foxseelady posted Thu, 03 March 2005 at 10:09 PM
Hi there, recently I downloaded an object in 3ds format. I can get it to poser, export as obj ext. However no matter what I do I cannot get it to texture? Is there something I am missing or that I should be doing other than the basic load and save I have done? Any help will be appreciated. :) Oh yeah I use PP.
ockham posted Thu, 03 March 2005 at 10:19 PM
3DS textures don't always work. Usually you can get better control of the textures by exporting the item as OBJ, checking the "include existing groups in polygon groups" box. Had you tried that already?
flyerx posted Fri, 04 March 2005 at 3:08 AM
Attached Link: http://user.txcyber.com/~sgalls/
You can use PoseRay to convert the 3DS model to OBJ first. It will keep the texture coordinates intact.See the tutorial in PoseRay's manual.
FlyerX
rreynolds posted Fri, 04 March 2005 at 10:00 AM
On the off chance that you're importing a 3ds object that has no texture, you might need to use UVMapper to give it texture coordinates
