Thu, Nov 28, 9:08 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 27 5:12 pm)
Subject: What 3D progs. allow you to create morph targets for Poser that work?
  • 1
  • 2
Kingfisher ( ) posted Sun, 13 March 2005 at 7:13 AM
gtrdon I imported the .obj into UVMapper & then saved it without the option to save the material file. Deep Exploration also worked ok. I would suspect that any explorer type 3D prog. that handles .obj should be alright. As long as they have the option to not save the material file. Another way is to load the .obj file as atext file into a text editor i.e. NotePad & remove all references to the following "usematl". Then resave. When the .obj is imported into Anapi Designer 7 check the scene tree, if it only shows one mesh then you should be ok. Before I do any alterations to the mesh I always export under a new name & check out the morph target within poser. When you move the dial nothing should happen.
gtrdon ( ) posted Sun, 13 March 2005 at 5:21 PM
Thanks KingFisher
Wow it worked!!! I have ask how to do this on several forums and even asked Tech support how to do this and have been told it could not be done with Amapi 7...Because it supposely changed the vertices!
This was the sole reason I bought Amapi a year ago..for morphing Poser characters
I wonder if this is known on some of the other Amapi forums where this problem has been posted several times.
Thanks Again
Kingfisher ( ) posted Mon, 14 March 2005 at 5:41 AM
No problem gtrdon. Im surprised Tech support said it could not be done. Its when I saw that amapi was creating more than one mesh when my suspicions were aroused. So I thought I only want one mesh & the rest is history. Makes you wonder how hard they tried.
unzipped ( ) posted Fri, 22 April 2005 at 3:08 PM
bookmark
  • 1
  • 2
