TRAVISB opened this issue on Jan 15, 2001 ยท 6 posts
TRAVISB posted Mon, 15 January 2001 at 1:15 PM
this question was recently asked but when i make a character and parent items to it i try to sve it and it only saves some of the parented obj i check the save as a whole grou[p is there something els i should be doing
JeffH posted Mon, 15 January 2001 at 1:21 PM
Are you saving the figure and it's parented props using the subset button? Don't use that feature for this. If the props are parented correctly they will save with the figure.
TRAVISB posted Mon, 15 January 2001 at 1:24 PM
the button on the right that is the plus sighn
JeffH posted Mon, 15 January 2001 at 1:28 PM
You said "save as a whole group"; are these props or figures?
Bladesmith posted Mon, 15 January 2001 at 9:25 PM
I seem to have the same problem, or close to it...made a winged figure, wings are considered separate figures, would like to make them one figure so i can load them with the character library instead of just a saved file...each wing is a figure, 3 in all...
JeffH posted Tue, 16 January 2001 at 1:22 PM
If you are using the Poser4.03 update, conformed figure will store to the library with the figure.
