thixen opened this issue on Mar 14, 2005 ยท 6 posts
thixen posted Mon, 14 March 2005 at 6:59 AM
I've working on a original texture for a character of mine. The texture is a white clown face inspired by Rhiannon's Chantal character. The problem that I'm having is though is that when I go to render I'm getting stripes on her chin anf forehead. Any suggestions??
thixen posted Mon, 14 March 2005 at 7:30 AM
ohh and Just to let you know for the above render all the checkbox options where checked on (including Texture Filtering) It was set to production mode Pixel sample 6 post filter 3
Starkdog posted Mon, 14 March 2005 at 7:42 AM
Just out of curiousity, what lighting setup are you using? I know that Poser's default vomit colored lights cast strange shadows. I have found that using a single infinite light set at 80-90% intensity, aimed at the nose works wonders. Oh yeah, on the light properties tag, set the shadow setting to 0.25, and then click on ray-trace render, rather than path-tracing. That seems to clear up my face renders. Which hair are you using? It almost looks like part of the trans-map is being shadowed onto her forehead. Anyways, I hope this helps, -the Starkdog
thixen posted Mon, 14 March 2005 at 7:50 AM
Starkdog posted Mon, 14 March 2005 at 8:43 AM
Cool, I'm glad that you got that fixed. Since you are in the process of "working on a texture", was that a jpg, or a psd file? I was just curious if the texture filtering somehow compromises a jpg, or if it can't handle the size of a psd? Thanks, -The Starkdog
thixen posted Mon, 14 March 2005 at 9:15 AM
I tried both. PSD files seems to work fine for me, but I usually put my textures into a Jpg when I'm done working on them because of size issues, and the fact that you don't need the layer information for a poser texture. The only reason I can see to use a psd file is if you were doing a super duper sized texture with lots of sublte color changes. Of course you'd have to ask whould those even come through? Also I could be wrong so anyone can feel free to correct me if they like.
